I need some insight....
Old Mar 6, 2008 | 08:15 PM
achTTung's Avatar
Default RE: I need some insight....
FYI, theres a service, and inspection reminder, with both milage and time notifications, eg: oil every 3 months/3000 miles, or inspection once a year. Its adjustable thru vagcom.
Old Mar 6, 2008 | 08:23 PM
Red_sapphire89's Avatar
ORIGINAL: Murderface
I changed my tranny fluid around 76k. It was pretty clean, but replacing it with MT-90 made it a lotttttt smoother. Also, if you don't have the 12-point security heads on your drain/fill plugs, you can just buy a set of big hex sockets from AutoZone for something like $7. Mine was just the plain hex bolt.
Thats good to know how many quarts does the tranny take 4? I am going to put that in my tranny when i do the clutch job i couldn't decide between mt-90 or MTL
Old Mar 6, 2008 | 09:09 PM
cincyTT's Avatar
I'm make believe
Most use MT-90
Dont hold me to this, but i believe the 02J's (fwd) have the Hex bolt and the 02M (awd) have the Torx.
Old Mar 6, 2008 | 10:14 PM
Murderface's Avatar
ORIGINAL: Red_sapphire89
Buy 3qts, 02J takes just over two, 02M is probably similar.
Old Mar 6, 2008 | 10:39 PM
Mininger's Avatar
ORIGINAL: diehlryan
Mine is usually set for 8,000mi oil changes I believe.
Same here.
Old Mar 6, 2008 | 10:43 PM
MeanAudiA6's Avatar
3qts will do the job...and the plug is a hex for our 2001 amus...if i remember correctly i use mt-90
Real380
Sep 6, 2012 12:32 PM
gb442
Aug 24, 2012 08:02 PM
GSoccer24
Mar 1, 2006 10:03 PM
A4Petro
Jul 13, 2005 08:45 PM
sbspeer
Jul 6, 2005 05:59 PM
