info on spacers
so my car has a 2" drop, but the back is not sticking out like I want it to because of the offset. i was looking at the ecstuning spacer kits, but I dont know what to get? Im pretty sure I need the 20mm for the rear, but should I go with the 10mm or the15mm?
depends on the offset of your current rim and width. use the offset calculator.
i usually go all around spacers (all around 20mm, not 15 front, 20 rear... i ono, thas jus me) and remember for the bolts, you take the OEM bolts (28mm) and add (+) the spacer size then you give or take (+/-) 2mm.
so 28mm oem bolts + 20mm spacers +/- 2mm = your good with 50mm bolts. yay
What width? I calculated it for a 7.5" rim and it came up with 29mm(30mm) front and 35mm rear.
Dunno if thats the right rim width though, so go ahead and try it yourself. http://www.2x.ca/TT/offset/
Well I just ordered 1 set of the ecstuning 20mm wheel spacers with bolts to try it out and see what I actually need, if the 20 mm are going to be good. 35mm seems a lot for wheel spacers and dangerous. Hopefully the 20mm wll be fine
ORIGINAL: achTTung
