Install Completed....
Old Feb 22, 2008 | 01:18 PM
cincyTT's Avatar
I'm make believe
Default RE: Install Completed....
First, do NOT increase the boost. YOu dont have the injector to fuel any more power. The problem i have with the elims are they lack the tq the real gt turbos have. When you finally get a tune (have ray get you a 630cc uni tune) and you can then run 24-26psi daily (only because the 225's have lower compression, 180's 24psi tops on pump).
And Red_sapphire, not all psi is the same. THe tq is what breaks rods. If he ran above 20 on a gt30 series turbo he would vent the block in a very bad way.
Old Feb 22, 2008 | 01:36 PM
Murderface's Avatar
By the way im running the Eliminator Kit GT2871R.... There were so many mixed reviews out there so i decided to be the Geine Pig to let you know how it runs, and so far so good! Also Cincy i finally installed the Turbo XS MBC today and my car holds at 20psi no problem.
There's your problem [&:] you're probably not making any big power until up top because the stock manifold flows like crap for a big turbo. Take it to a dyno and see your power curve, it probably starts climbing real late.
ORIGINAL: jojoenglish85
im still running stock injectors, and i never had a boost controler on the ko4. Im running a GIAC chip also, i just feel like there should be more power but maybe im just thinking i should be driving an audi R8 or something.
Stock injectors+stock chip isn't going to make all that much power either. All your timing+fuel trims are set up to spool and power a K04, not a turbo that flows a lot more
I will be running bigger injectors 550cc by genesis so maybe that will help out,
Those will support about 350whp. Your stock injectors are 380cc's, assuming you started with a 225. I don't think you could hit 300whp with them. Maybe with a 4-bar FPR you could.
I really like it, but from a roll i just feel slower, maybe our cars aren't made for it or something....
The Mazdaspeed 3 is about the same weight, but with that K04 it probably has a much wider powerband than your elim. It probably hits power sooner, which would be reasonable cause for it to be winning.
Im actualy wanting to have a custom map done for my car now, is there anyway that the guys in the DYNO shop can do this for me or where do i need to go to get a custom map done? I figured the DYNO guys could do it, i think the car will realy be able to shine then once its been mapped over again.
I highly doubt your dyno shop can do anything with our ECU's, usually only major chip tuners really have the means to do anything. If you go to Revo or someone they can probably tweak their BT software to your needs.
Let me know when you want your stuff btw
Old Feb 22, 2008 | 01:51 PM
AudiOso's Avatar
I'll take your stock injectors off your hands if you are interested when you get your 550s. I am doing a stage 1+ on my Avant and need TT 225 injectors for it. PM w/price.
Old Feb 22, 2008 | 02:00 PM
cincyTT's Avatar
I'm make believe
380's @4bar = 440cc @3bar and will support 300fwhp.
Like murder went into more detail about. The elim adds another 500rpms or so of lag and kills the tq. Also dont think your going to make simular power (or curve)as a apr or pag kit.
Old Feb 22, 2008 | 06:22 PM
jojoenglish85's Avatar
well it deffinately feels like i lost some torque but im realy not sure if its because im running no cats and 3" from turbo back.
But i think your right, i need a Revo Stage 3 by next weekend and im in Houston, so if anyone knows a place in houston i can get one then im down or you can send me an ecu with stage 3 on it already. I can't get driving like this anymore than a week. Also i will post up a video and pics of how the car runs tonight so yall can see for yourself.
Old Feb 24, 2008 | 04:08 PM
here is the video of the things i installed on the car:
enjoy!
http://www.youtube.com/watch?v=CUl4nyWjyYg
Old Feb 25, 2008 | 12:57 PM
nobody likes the way it looks or sounds?
Old Feb 25, 2008 | 01:10 PM
  #18
moeron7's Avatar
hahah you called it a giac (guy-ack) chip. Its pronounced individualy lettered.
Old Feb 25, 2008 | 01:11 PM
  #19
cincyTT's Avatar
I'm make believe
The car looks good. Just get that thing tuned and please oh please dump that stupid intake. You will need a much larger intake than that to push the power your hoping to get.
Old Feb 25, 2008 | 01:19 PM
  #20
shroom filter ftw... I just called giac to find out about an upgrade they will call me back around 3pm
