lowering springs and stock struts?
Old Jan 11, 2012 | 06:58 PM
IronCobra53's Avatar
Default lowering springs and stock struts?
i have an 03 fwd and i was wondering if i can put in lowering springs( h&R neuspeed etc..) with my stock struts/ shocks ? i hve 78xxx miles on my tt currently, id replace all the bushings but jst wondering if the stock struts would be ok thnx in advance -Rich
Old Jan 11, 2012 | 09:35 PM
cincyTT's Avatar
I'm make believe
They are at the end of their lifespan and if they are still ok, they will be working harder and go bad faster. New stock replacements should be fine with a modest drop of an inch. Just not something you want to do twice. If money is tight, at least do the fronts since the rear shocks are a easy to swap.
Old Jan 12, 2012 | 11:52 PM
ok i plan on only goin around 1-1.3 inches ( thts wht h&r says their springs lower) so ill prob get oem struts or maybe bilstein ones
Old Jan 16, 2012 | 11:18 PM
arnolds64's Avatar
Running Neuspeeds Sports with Monroe Spec Sensatracs. Seemed to be pretty good. The Struts/Shocks are new though. Pretty stiff compared to stock.
Old Jan 16, 2012 | 11:28 PM
i live in a town with a ton of potholes so i dont want to be scrapping everytime i hit a bump but my tt would look sooo nice lowered
Old Jan 17, 2012 | 02:22 AM
achTTung's Avatar
Moderation in lowering, because THIS:
Leads to THIS:
And I pulled that oil pan right in the hooters parkinglot, and after welding it, reinstalled it at night during a thunderstorm. FFFFUUUUUU......
Old Jan 31, 2012 | 12:20 AM
arnolds64's Avatar
The Neuspeed only dropped it about 1.25". Not near as far as achTTungs. It has at least 4" of clearance. Madmax also did a huge right up on suspension and spoke about how going too low will make it handle worse.
Old Feb 2, 2012 | 02:03 PM
rodhotter's Avatar
i just installed eibach pro kit about 1" lower, and new koni FSD shocks + struts, did rear myself alignment shop did front with 4 wheel alignment, even doing yourself you need an alignment, even if you get plain jane struts and shocks your better off with all new parts. update VERY nice car handler better and a nicer ride, although 37xxx on stockers 11yrs takes its toll, car used to thump when i hit a rough spot, not any more, labor is same to install any setup even if your stock almost stockers go back on
kwheels
Oct 28, 2013 10:23 AM
Audibility2run
Feb 24, 2012 11:57 PM
A4 2000
Aug 26, 2011 12:59 AM
audib5971
Apr 13, 2009 12:25 PM
lostinnd
Jul 23, 2008 01:06 AM
