MAP Sensor
Old Jul 5, 2007 | 09:47 AM
Indiepunk's Avatar
Default MAP Sensor
After replacing my -A MAF with the one that is suppose to be for my car -D my car started running even worst. I'm running without it connected for now. My mechanic put in a green top to see if that was the problem but it wasn't. He suggested replacing the MAP sensor. I am planning on taking the front bumper off to do the headlights so I figured I'd save the 2 hours on labor and change the sensor myself. I didnt see a MAP sensor on ECS or Ebay. Short of calling the dealership has anyone ordered one of these online?
Old Jul 5, 2007 | 10:14 AM
cincyTT's Avatar
I'm make believe
Default RE: MAP Sensor
maps usually dont die (atleast from what i have seen). you may have a dirty one covered in oil, but im sure its not dead. Its entirely differnt than a maf. I would have codes pulled to see what else it could be first.
Old Jul 5, 2007 | 10:47 AM
ouTTie914's Avatar
Not sure of the difference between an -A maf and a -D maf.
Just make sure the maf you bought is the correct one for your engine code.
Old Jul 5, 2007 | 12:03 PM
Indiepunk's Avatar
ORIGINAL: ouTTie914
06A-906-461-D is for the 180HP and 06A-906-461-E is for the 225HP. Mine actually is a 06A-906-461-DX which is a rebuilt. It seems a lot of people put in 06A-906-461-A from the old 2.0 engines because the rebuiltsare only around $90 end user. It is big profit margin for a reseller considering I paid $180. Not that I couldn't change it myself. I paid the price for the diagnosticsand can't be mad cause the mechanic spent at least 2 hours trying to trouble shoot it this last time at no cost. On the other hand I'm not any closer to understanding the cause of my problem. Looks like I should I'll try the mechanic at VW once more.
Old Jul 5, 2007 | 12:25 PM
225tt's Avatar
^^^^^Good to know!
Old Jul 5, 2007 | 12:57 PM
theTTkid's Avatar
good to know 2x
Old Jul 6, 2007 | 12:03 AM
TSRgeneral's Avatar
ORIGINAL: Indiepunk
Its worth doing it yourself. Follow the instructions on how to take the front bumper off, and on the top of the intercooler there is the Map. You can take it out easily, clean it if it looks dirty or buy a new replacement. here is the DYI i used to take off my bumper.
http://www.wak-tt.com/mods/angeleyes/bumperremovals.htm
Good luck
Old Jul 6, 2007 | 02:04 AM
225tt's Avatar
So if the difference in MAF's is a big deal, how come I can go and get a VW 2.0t maf or a S4 maf and it will run just fine in my car?
Old Jul 6, 2007 | 01:17 PM
cincyTT's Avatar
I'm make believe
you dont need to ever change your maf. They just changed the size of the hole for it form small to slightly bigger. Just because its bigger doesnt mean its better. THey both still read the same and to 5v (~22psi)
The mafs come down to differnt housings. The larger the housing the more g/s the car reads. Some tuners require it for bt sw. Some tuners tell you to keep your current maf element (with larger housing) and some tell you to use the element for the housing your using.
In my other thread i cleaned my map, it was covered in oil from a pool of oil sitting in my ic.
neomaxddr
Apr 1, 2009 03:16 AM
