misfiring - what could it be
Old Nov 17, 2008 | 02:23 PM
dazw1's Avatar
Default misfiring - what could it be
Hi,
I have a 1999 TT 1.8 Quattro. It has recently been starting to misfire, and doesnt idle as smooth as it should. Just wondering where's best to start? My guess is spark plugs and coils?
Old Nov 17, 2008 | 02:39 PM
Mobius97's Avatar
You got it. First things first change out the spark plugs if they haven't been in the last 15k miles.
If the trouble persists find out what cylinder is getting the misfire and then swap out the troubled cylinders pack with one of the other 3 to see if the trouble follows the pack.
Those are the first steps to take IMO.
Old Nov 17, 2008 | 03:25 PM
cincyTT's Avatar
I'm make believe
if its bad at idle, the packs should be fine. Just spend the $10 and change the plugs and make sure they are gapped correctly. The packs should misfire until you actually try to accelerate
Old Nov 18, 2008 | 04:05 AM
dazw1's Avatar
how do i find out which cylinder is misfiring?
Old Nov 18, 2008 | 04:23 AM
theTTkid's Avatar
^if your misfiring youll throw a CEL... just scan the cell and it should tell you which cylinder it is...
Old Nov 19, 2008 | 12:28 PM
dazw1's Avatar
sorry, you'll have to explain how that is done. never done that before. How do I scan the cell? where/what is the cell?
Old Nov 19, 2008 | 02:30 PM
sacgns's Avatar
i had similar problems with my car an chaged the sparks an packs an still misfired. check all you pcv hoses an lines i had a crack in one of mine that was causing it once i fixed it the misfiring stopped.
Old Nov 19, 2008 | 05:41 PM
jakej's Avatar
cel=check engine light. Go to autozone or advanced auto parts and ask them to scan your car. They'll do it for free right on the spot. Buy new spark plugs while your there as well. Make sure you gap the new spark plugs correctly. It says the gap's on the sticky at the top of the forum.
cncbamf
May 9, 2017 05:39 PM
googlegot
Jun 10, 2012 06:25 PM
tketke
Nov 4, 2008 12:01 PM
limptimtim
Mar 16, 2007 11:21 PM
nitro_rider2001
Feb 27, 2007 07:39 PM
