my quattro isn't working I hope someone can help
Old Nov 30, 2007 | 01:27 PM
cincyTT's Avatar
I'm make believe
Default RE: my quattro isn't working I hope someone can help
I only have ASR, not ESP and my rears never get any power. BTW, somebody thinks theyre funny [8D]
Old Nov 30, 2007 | 01:38 PM
WishIWasRWD's Avatar
Who, me?
Old Nov 30, 2007 | 01:40 PM
cincyTT's Avatar
I'm make believe
You, NEVER
Old Nov 30, 2007 | 04:28 PM
eliTTe's Avatar
ORIGINAL: cincyTT
your RWD bearings must be locked up!
Old Nov 30, 2007 | 04:31 PM
bmwtoaudi's Avatar
2000's 180's have an APR button. - Mine doesn't work because I have wheel speed sensors out... but who needs those! - My computer doesn't EVER take over my car when I'm breaking or turning!
Thought about getting it fixed, but since I drive my car like I stole it, I figure its best to leave it off....
Old Nov 30, 2007 | 05:17 PM
Murderface's Avatar
ORIGINAL: bmwtoaudi
DOOD YAH mine too it enables my ballin APR STAGE 3++++ with 110 octane CHOON!
How about you check your haldex fuse...position 31
Old Nov 30, 2007 | 11:06 PM
mpower1226's Avatar
The 2000 models did not come with esp as far as I remember, what you see when you turn the key on on the instrument cluster is actually "epc" in yellow light. electric power control that controls your speed up 80km i think in case of slipping.
Old Dec 1, 2007 | 12:35 PM
  #18
achTTung's Avatar
EPC reduces power in the event of some sort of failure that the car sees as threatening to the engine, its not speed control exactly, although you will be slowed down. Think of it as super limp mode.
As for the haldex issue, run the roll out test, but it sounds like you've done a pretty good job of varifying that its not hooking up.
You'll need to check the car for DTC's, I'd almost put money on you finding 'internal memory malfunction' or something along those lines, I can't remember exactly what the code is called. Far as I know in that case, is theres not really a repair for the controller, you'd need to replace it. I went thru the same thing, snagged a Haldex blue controller for $750. Easy install at least. That splits power more 50/50, and I wish I had a video camera last night when I was doing donuts in the parking lot. The car eventually gets into a fast spin pivoting around a point almost centered in the car. Wild.
Old Dec 1, 2007 | 09:14 PM
  #19
cincyTT's Avatar
I'm make believe
ORIGINAL: bmwtoaudi
ASR
Old Dec 3, 2007 | 08:18 AM
  #20
BlackRaptor's Avatar
Thanks for all the good info.
with hte ice storm this past weekend i think the TT is trying to kill me. going to check the things you guys listed above. thanks again.
Timon
Jan 16, 2013 02:57 PM
Boston - Audi96Q
Dec 6, 2012 12:02 PM
theperfecto1
Mar 16, 2007 04:16 PM
frankinstyn
Mar 15, 2007 01:23 AM
GFA6
Mar 11, 2007 02:01 PM
