need to change Timing belt? ---->(New question, scroll down please)
Old Apr 25, 2007 | 09:31 PM
Murderface's Avatar
Default RE: need to change timing belt, what else?
While you're doing the timing belt do the waterpump.
saw your thread on VWVortex too
Old Apr 25, 2007 | 09:58 PM
ouTTie914's Avatar
The ECS and Diesel Geek kits come with a metal impeller water pump.
Old Apr 25, 2007 | 10:05 PM
gTT's Avatar
gTT
Old Apr 25, 2007 | 10:16 PM
Dana Reed's Avatar
By "drain the block"are you referring to the hose that goes into the oil filter adapter? I did that (lots of skinned knuckles trying to remove the hose stuck to the fitting) but even then it didn't take as much coolant as it calls for. Are there other drain plugs elsewhere?
Old Apr 26, 2007 | 12:01 AM
achTTung's Avatar
i had who knows what for coolant when i did mine last weekend. I opened the drain on the radiator, and put the hose in the death star, which you might call an expansion tank, and let it run until what was coming out of the drain was clear. Closed it back up, let the car warm up so I knew the thermostat was opened completely, an repeated the process. This time instead of using the hose, i used bottles of distilled water. Ran about 4 gallons thru the system. Let the level drop in the radiator enough to fit 2 L of coolant, but with enough water that I could bring the system to the full level if I still needed. I didn't feel like pulling any more coolant lines off the car to drain it than I had to, so even if this used a shitload of water, its still my prefered method.
BTW, whats not mentioned for those who want to do their own timing belt, is that you're gonna spill PS fluid, so make sure you get a bottle of that bofore you get started, or endure the terrible screeching noises of a dry PS pump when you drive to get some afterward. ; )
Old Apr 26, 2007 | 12:37 AM
Z06guy's Avatar
Wouldn't hurt to do spark plugs and a Haldex service too.
Old Apr 27, 2007 | 08:14 PM
gTT's Avatar
gTT
I ordered the timing belt kit from ECS and I found out dieselgeek's kit has the Thermostat housing cover. They said "replace it every time you touch it!".
Do I really need to order this part? Why ECS won't included this as dieselgeek stated that need to replace it.
thanks!
gTT
Old Apr 28, 2007 | 06:09 AM
  #18
achTTung's Avatar
seems sturdy, don't know why they'd recommend it be replaced. You're probably safe reusing the thermostat housing you have.
Raybbaby
Aug 4, 2013 02:08 AM
WDSmith485
Mar 21, 2010 11:10 PM
mikekirchner
Jan 30, 2009 02:01 AM
mikekirchner
Jan 29, 2009 10:32 AM
mustang196718
Feb 23, 2007 05:03 AM
