need a clutch!!!!
Old Jan 6, 2009 | 05:42 PM
sacgns's Avatar
Default need a clutch!!!!
so i was coasting up to a light with my car in third gear with the clutch all the way down, when out of no were there was a pop an the car went back into gear. i had to drive it 5 miles without a clutch to get it home. so we have figured out that the prob is that the master cylinder and slave cylinder is wat went bad. not to bad except i have to replace the master and slave cylinder plus the entire clutch. now here is my question what is a good setup to go with since i do not wat to put a stock clutch in it. any ideas or recomendations?
Old Jan 6, 2009 | 06:03 PM
myslow1's Avatar
lol at least you could drive yours. My tob went out and i coasted in first gear for about half a mile until i got to a red light. It was all over from there haha. I dont know what people run i just went with an oem replacement for time being.
Old Jan 6, 2009 | 06:08 PM
sacgns's Avatar
ya its not to hard to drive without a clutch only thing that sucks is stoppin cuz you have to shut the car off an put it in gear to get to move.
Old Jan 6, 2009 | 06:36 PM
01slowS4's Avatar
What model/year is the car? I have a rs4 pressure plate and clutch disc that i just took out of my car. It is not perfect but it still has some good miles left on it. I live in Northern CA if you are near hear you could come check it out or I can send you some pics. Otherwise the clutch you want depends on what you use the car for and the power it makes.
Old Jan 6, 2009 | 08:11 PM
sacgns's Avatar
i drive a 2002 tt quattro 1.8t, im most likely goin to go with a south bend or spec clutch. its good for 310trq an i dont plan on makin more then that anytime soon. an while the tran is down im prob goin to put a short shifter in.
Matt_Iliketurbopull
May 1, 2007 05:28 PM
Matt_Iliketurbopull
Apr 28, 2007 03:06 PM
