need some help - i keep blowing up DP's
Old Apr 22, 2008 | 06:35 PM
chosos's Avatar
Default RE: need some help - i keep blowing up DP's
they are re-welding the original weld where it broke off free of charge. he said because I used a "universal" O2 sensor that it must be running hot and the heat broke the weld. He stands by his work. He is a nice enough guy. He also said he wouldn't put the 2.75" DP on and said it was WAY too tight for it to fit and wasn't comfortable doing the job.
I imagine that at some point, I will try and find a shop who is willing to put the 2.75" DP on and also willing to remove the cat at the same time.
They used the factory flange from the stock 180q DP to create the 2.5" and it is stainless, and I know the pipe he welded it to was not stainless, so hopefully he used the right rod for the job.
Old Apr 22, 2008 | 06:53 PM
cincyTT's Avatar
I'm make believe
The sensor has nothing to do with it. Your engine shakes to much and breaks the welds. Stiffen the mounts and you will be fine. Just remember that there are about a dozen other people running that dp and no one has posted any problems.
ScottBH
B7 Models
Aug 27, 2014 03:18 PM
vtraudt
Jan 10, 2014 11:27 PM
neilechols
Jul 31, 2012 11:55 AM
BLS
Dec 12, 2011 03:33 PM
Hecareth
Apr 19, 2008 12:24 AM
