new owner and first minor problem
Old Sep 3, 2007 | 12:12 PM
cspinner's Avatar
Default new owner and first minor problem
I recently purchased a 2001 180hp TT coup. I am impressed to say the least. This little car is smooth! The first thing I noticed though, is that I am leaking wiper fluid. I traced it to the passenger side headlamp jet area. After it retracts, it begins to leak profusely until I am out of fluid. Is there an easy way to get to this assembly without taking it to the stealership? Has anyone had this problem?
Old Sep 3, 2007 | 12:58 PM
cincyTT's Avatar
I'm make believe
Default RE: new owner and first minor problem
Mine had leaked also. Its just rubber hose and clamps and they can leak due to wear. If you dont mind taking off the front bumper you can access the problem and repair/replace the damaged area of hose.
Old Sep 3, 2007 | 05:01 PM
cspinner's Avatar
Thanks. It turns out the nozzle on the head of the jet is missing. So, whenever it turns on it sprays like a garden hose. I'm going to assume the loss of pressure that results prevents the driver's side nozzle from poking out...
Is there a web site you folks use to order oem parts?
Old Sep 3, 2007 | 05:49 PM
Jays TT's Avatar
I had the same problem. It broke in the winter time. When I got my new bumper I just disconnected the squirters and pluged the hose so It just goes to the windshield. I might have the passenger squirter left. I;ll have to look though.
Old Sep 3, 2007 | 09:27 PM
cspinner's Avatar
ORIGINAL: Jays TT
I'd appreciate it!!
Also, after reading the FAQ it appears like I should get this timing belt replaced. I have 54k miles on it and murphy's law states that it will break before the next 6k miles. I don't have the tools/knowledge to do it on my own. How much do you think it will cost to get done at the dealer?
Old Sep 3, 2007 | 10:34 PM
cincyTT's Avatar
I'm make believe
dealer will cost $1000-1200. if you get a tb kit from deiselgeek or ecstuning you can save some money by having a shop do it for less.
cheapstudent
Jan 25, 2012 06:49 PM
TM (Ghost)
Aug 31, 2009 06:12 PM
Jonamond
Aug 20, 2009 06:52 PM
weaselciuy
Nov 13, 2008 06:15 AM
frencha99.5a42.8q
Apr 26, 2006 10:03 PM
