Nitrous
Old May 15, 2008 | 02:28 PM
PaTTy225's Avatar
Default RE: Nitrous
If I have a chip, vtda, **** and BM will that affect anything? Can I still run 20-22 lbs of boost with the juice?
Old May 15, 2008 | 10:52 PM
theTTkid's Avatar
Default RE: Nitrous
yes, the thing i said you have to be careful with is torque... again, nitrous at low rpms will increase your chance at breaking your internals....
vtda... meh, i have one, and took off the can around the cone filter, works better...
****... dont get it, really is a true waste...
BM... once again, an over priced boost controller
Old May 16, 2008 | 08:58 AM
PaTTy225's Avatar
Default RE: Nitrous
what would you recommend to me instead of the **** and boost machine....it looks as if ill be running the 50 shot to be on the safe side with the accessories and window switch set at around 4200 rpms.....also is it still ok to run this shot at 22-23 lbs of boost?
Old May 16, 2008 | 05:32 PM
cincyTT's Avatar
I'm make believe
Default RE: Nitrous
Stock maf and a normal bleed mbc.
You will be fine running 20-22 (no reason to run more) psi with spray
darkside2303xxx
Jun 30, 2010 09:47 AM
java
16
Jan 23, 2008 04:55 PM
prosperousJ
Oct 18, 2007 03:28 PM
S4rider
Nov 13, 2006 03:53 AM
