Noisy wastegate
Old May 6, 2008 | 12:33 PM
Skipponator's Avatar
Default Noisy wastegate
Anyone have a noisy wastegate after install of a boost controller? Are there any benefits from doing different wastegates?
Old May 6, 2008 | 12:53 PM
Murderface's Avatar
Default RE: Noisy wastegate
No benefits on a stock turbo.
And that noise probably isn't the wastegate...just lots of airflow through the compressor
Old May 6, 2008 | 01:55 PM
cincyTT's Avatar
I'm make believe
cant hear an internal wastegate
Old May 6, 2008 | 02:59 PM
moeron7's Avatar
What does an external wastegate sound like?
Nevermind
Old May 6, 2008 | 07:50 PM
MeanAudiA6's Avatar
ive asked the same question since forge sells a replacement wastegate never heard of a benefit tho
Old May 7, 2008 | 12:25 AM
My local Euro shop said it was the wastegate opening and closing. It only happens at partial boost, like 5psi-12psi. It's like a metallic *****? I dunno how to describe it.
Old May 7, 2008 | 02:37 AM
Murderface's Avatar
I don't think there's any way you could hear that tiiiiiiny wastegate opening/closing over the exhaust.
My guess would be it's your DV opening/closing since the ECU uses it to control partial boost.
Old May 7, 2008 | 10:36 AM
cincyTT's Avatar
I'm make believe
ORIGINAL: MeanAudiA6
It has a higher psi spring and will build and hold boost better. not worth it on a 180 but should be a decent improvement on a 225. However for the price, i would just get a greddy ebc and get the same if not better results, not to mention transferable to a new turbo set up
nugger
Feb 5, 2009 06:29 PM
mckinneyA8l
May 10, 2007 02:17 AM
rkohan
Oct 21, 2006 07:32 AM
biddy
Mar 14, 2006 07:17 PM
Palfreen
Nov 11, 2005 06:52 PM
