odd issue
Old Oct 8, 2007 | 11:07 AM
ooantipostoo's Avatar
Default odd issue
Ok so i came across a very strange problem. My car seems to show boost 15psi but it almost feels like it kicks on then die's off again. But when it does this the boost is still reading 15psi. So im not sure what going on hear any ideas?
Old Oct 8, 2007 | 02:20 PM
cincyTT's Avatar
I'm make believe
Default RE: odd issue
sounds like something is not right and the engine is pulling timing. Could be as simple as bad gas or a dying maf
Old Oct 8, 2007 | 02:25 PM
A4nicator's Avatar
boost leak? How many miles on the engine?
Old Oct 8, 2007 | 02:29 PM
quattro411's Avatar
could be a number of things as mentioned already, maf, boost leak, spark plugs, coil packs, etc.
did your CEL come on?
if so what codes?
Old Oct 8, 2007 | 02:35 PM
No cel yet. Im almost certain its not a boost leak. I will try unplugging the maf on the way home from work. How far can you drive with it unplugged. I know your car will go into open loop eventually but is it ok to drive with it unplugged for about 20 minutes or so? Ill go aheand and check the plugs today too.
Old Oct 8, 2007 | 02:39 PM
100k on engine....its not a boost leak
Old Oct 8, 2007 | 02:50 PM
cincyTT's Avatar
I'm make believe
i thought my maf was bad and ran the car w/o the maf for a few months. Found out when my engine was pulled that the bolt holdingthe tip on was missing and it wasnt attached. D'oh!!
nelson0639
Dec 8, 2014 04:44 PM
hotswaps
Aug 8, 2013 05:50 PM
hotswaps
May 27, 2013 07:02 PM
Dallas09
Feb 14, 2009 05:08 PM
2001A6
Jan 9, 2009 02:41 AM
