Oil leaking from inside Frame Rail (Lift points dripping)
Old 12-15-2008, 06:02 PM
jakej's Avatar
Thumbs up Oil leaking from inside Frame Rail (Lift points dripping)
I noticed a few small drips leaking out from where the rear driver side lift point is. The little rubber pad was litterally covered in this clear oilly substance. It maybe leaks 1-2 drops a day, if the rubber lift point is not cleaned.
The dealer told me it was an anti-rust inhibiator. It's a common problem. Just a heads up incase anyone else has this problem. Pretty cool Audi use it.
Old 12-15-2008, 09:10 PM
BMF!'s Avatar
does it look like sort of a wax / vaseline mixture? I'd just leave it alone... I think the manual says to put padding on the top of the jack to prevent damage there.
Old 12-15-2008, 09:54 PM
jakej's Avatar
No. It feels just like oil, but clear. It's not thick at all.
Old 12-15-2008, 10:03 PM
BMF!'s Avatar
Your car is leaking KY jelly..
Old 12-16-2008, 05:27 PM
achTTung's Avatar
never heard of the stuff. black tarry stuff is called cosmoline, usually see it around the seam of the rear bumper and the quarter panel. Theres more of a seam sealer wax that might be clear, but I wouldn't expect that to be dripping unless its really freaking hot.
Old 12-16-2008, 06:11 PM
AWDrifter's Avatar
I have some of that black tarry stuff in the rear quarter area, never knew what it was. Whats the purpose?
Old 12-16-2008, 08:03 PM
achTTung's Avatar
sealer/undercoat. It's not just an Audi thing, its on pretty much every car produced. It's just a problem on TT's... My car is almost 8 years old, and that stuff is still working its way out around the quarter.
Old 12-16-2008, 11:26 PM
AWDrifter's Avatar
What do you recommend to get it off with?
Old 12-17-2008, 12:21 AM
jakej's Avatar
The rust inhibitor is very liquid-ish even at 32 degrees F. It's identical to oil, but clear. The audi dealership said it was common. I bet mine just "sprung" a leak and a lot of it dripped out at once, rather then slowly. There was enough to clearly see a leak occured. Maybe 2/3's pint leaked out.
Old 12-17-2008, 11:52 PM
XCLR8TT's Avatar
I used a Q-tip with a little bit of rubbing alcohol.
mngkaren
11-09-2013 04:26 PM
Saku
B7 Models
11-10-2008 07:04 PM
retiltxet
07-27-2008 03:44 PM
crabman
07-21-2007 12:58 PM
Big Hank
11-12-2006 02:33 PM
Quick Reply: Oil leaking from inside Frame Rail (Lift points dripping)
