power window and brake light problems
Old Feb 4, 2005 | 12:15 PM
soward's Avatar
Default power window and brake light problems
Does anyone have a wiring diagram which includes the power windows and brake lights.
Or better yet has anyone seen an instance where both stop working.
It's not a fuse, I've check them all. Over the past 1.5 years I have blown a fuse which controls
the interior lighting, alaram and power window controller (#14) twice, but I figured it coincidence.
Interestingly when I opened the door, the drivers window rolled down, not the 1/4" it usually does,
but about 4"... Now the windows are dead and interestingly so are the brake lights.
I suspect either there is another fuse somewhere other than the dash panel, or there is a bum relay
somewhere under the hood.
Updated: The two failures are unrelated. The Brake light was just a stuck brake light switch near the
brake pedal. A little manipulation and silicon lube seems to have fixed that issue. The windows,
however, are still stuck.
thanx,
Old Feb 8, 2005 | 02:49 PM
BoostedTT's Avatar
Default RE: power window and brake light problems
For your window issue.....
My passager window was stuck in the up.
After removing the door panel with the 1 screw holding it on. I noticed the motor was hot. I grease the cable and manually moved the window up and down via the pully. Has worked great for over a year now with no problems.......
This may not be the same problem but I thought I would give you an idea.....
Good Luck
Old May 11, 2005 | 12:56 AM
jennystt01's Avatar
I fixed the brake lights the same way Soward did. The switch was stuck. Just got underneath the console and loosened her up. Thanks Soward.
Old Jul 8, 2005 | 11:14 PM
Point_Zero's Avatar
Did you find out reason for interior lights, power windows. Cause fuse 14 blows consistently, there is a short for sure but where, I am trying to find out????
Thanks for your help..
Ozzy
ORIGINAL: soward
thanx,
Old Aug 5, 2005 | 01:55 PM
MartinTT's Avatar
I've got a passenger window problem.
My passenger window button doesn't work but the window works if I use the drivers side button.
Old Aug 15, 2005 | 03:47 AM
dclaw_fantum's Avatar
Does your DIS show that your door's open, or is it unresponsive?
johoko
Sep 29, 2015 02:55 PM
vthunter1
Jun 11, 2014 08:27 PM
ceroberts75
Dec 11, 2013 01:46 PM
thepirate
Mar 16, 2013 12:05 AM
wisethug0
Oct 28, 2005 07:02 AM
