Power Window Problems, Need Help!!
Old Sep 15, 2013 | 03:37 PM
vthunter1's Avatar
Default Power Window Problems, Need Help!!
Seeing as I cant get my car inspected until my window works, some fast help on this would be much appreciated! So thank you in advance.
I have a 2005 A4 1.8T and recently my front passenger window started responding very oddly. All my other windows work fine but the drivers side switch for my front passenger window doesn't work at all and my passenger switch for it always will make it go down but when you try to put it up, sometimes it will work fine, sometimes not at all but most the time it will go 3 inches, stop, 4 inches, stop, and just act very glitchy.
I suppose it's most likely my front passenger switch but i don't understand why that would make my drivers side switch totally not work. Any advice would be great.
Thanks again!
Old Sep 15, 2013 | 10:18 PM
vthunter1's Avatar
Default Edit:
Also, my front passenger switch does have constant current making it light up when I turn on my headlights.
Old Sep 17, 2013 | 04:46 AM
johannes.els's Avatar
Hi all i am new here and can’t find a answer to my problem >
Well hope someone can assist
I have a 2004 Audi a4 1.9tdi my issue is from my driver’s door i can control all the windows and they work fine however from each doors own switch they stat problems
The front passenger door can open but can’t close and the rear door cant open their windows but can close them
The master switch all works except when you open the driver’s window the one touch does not work down but works up
Where do I start looking for a problem please assist
Old Oct 29, 2013 | 10:27 PM
klipsch21's Avatar
Could be the common door harness problem. Check out this video. It shows what could be the issue and how to check for it:
Old Jun 11, 2014 | 08:27 PM
Izzo02's Avatar
Vt hunter,
I feel like you may have 2 problems. The right front window not working from the drivers side would point to an issue with the master switch/ faulty.... When the passengers window does go up and stop, does it just stop or does it go back down?? The window motors are set up to retract if they notice excessive resistance,( they think something is stuck in the window path.. Fingers) you can try to apply some silicone lube to the window track,if that doesn't help, the window regulator may be going bad and the cables may be starting to fray...
johoko
Sep 29, 2015 02:55 PM
thepirate
Mar 16, 2013 12:05 AM
h4x0r
Dec 31, 2011 12:20 PM
wisethug0
Oct 28, 2005 07:02 AM
soward
Aug 15, 2005 03:47 AM
