Question
Old Dec 13, 2008 | 11:49 PM
Joekenny187's Avatar
Default Question
i been having problems with my 2001 audi tt quattro. i was wondering if anyone could please help me out. my car eventually dies while driving. ive change the alternator twice and have changed the battery 4 times. the alternator is putting out 14volts and have tested it numerous times. when i disconnect the positive terminal from the battery the car dies. the car will only run off the battery dieing every couple days. i have done a couple continuity test, checking the battery's ground, and between the output terminal of the alternator and the battery's positive terminal and all show up good. i am lost at what to do next and would greatly appreciate some advise
Old Dec 14, 2008 | 11:24 AM
cincyTT's Avatar
I'm make believe
Do you get an ESP light when it dies? Anything done to the car?
Old Dec 15, 2008 | 03:30 AM
no the esp light does not come on. i havent done anything to the car. i bought it about 6months ago and it worked fine for 2 months then it started having problems for the first time and i changed the alternator and worked fine for about 4months untill this past thanksgiving i took a trip and thats were it started giving me problems so i figured it was a bad refurb alternator so i replaced it again jus to find out the car would die later that day. right after i installed the altenator i took it to the auto store to get it tested. they said it was working fine.
Old Dec 15, 2008 | 09:22 PM
BMF!'s Avatar
hmm.. that has to be annoying. Check that your terminals are extra clean and maybe check the cables. I would imagine that's probably the first thing you did tho..
Old Dec 16, 2008 | 02:36 PM
yeah its pretty annoying lol. i checked all the terminals and wiring. when i follow the fat power cable coming off the alternator spitting out 14 volts, i trace it to some kind of distribution block on top of my starter and then after w.e this distribution block is it goes to the battery. i think my problem is in this spot but i dont know what this part is or what it does. does any1 know what this part is called? or maybe has a website were i can access some wiring diagrams?
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
