Question about changing brake pads
Old Mar 9, 2008 | 05:51 PM
doadea's Avatar
Default Question about changing brake pads
I am changing my front brake pads on my TT and it looks like I need some sort of hex tool to loosten the caliper guide bolts. Does anyone know what size hex tool this is? Thanks!
Old Mar 9, 2008 | 05:54 PM
cincyTT's Avatar
I'm make believe
Default RE: Question about changing brake pads
Believe its 8mm but dont hold me to that. Was about a year since i did mine and i dont have stocks anymore
Old Mar 9, 2008 | 10:46 PM
doadea's Avatar
I found it...it's a 7MM Hex.
Old Mar 11, 2008 | 10:16 AM
doadea's Avatar
I changed my brake pads..the drivers side took me about an hour because it was the first time I had done it on this car, and it took me a while to get the pad sensor unhooked, as it was very stubborn. I also took off the entire caliper support, which I did not need to do.
But Damn! I did the passenger side next, I only took off the caliper (left the support) and it only took me about 10 minutes for the entire job. Talk about easy!
Old Mar 11, 2008 | 10:29 AM
cincyTT's Avatar
I'm make believe
did you get new rotors or atleast resurface the old ones?
Old Mar 11, 2008 | 10:38 AM
doadea's Avatar
ORIGINAL: cincyTT
No I did nothing with the rotors. The only reason I put these new brake pads on was because I was sick of the dust of the OEM pads. I would clean my wheels and they would be dirty again the next day it was bad. The OEM padswere only about 1/2 used.These new padsare just temporary until I upgrade to a big brake kit in a couple months. I did inspect my rotors and they had no grooves, etc and were in excellent condition.
Old Mar 11, 2008 | 10:45 AM
cincyTT's Avatar
I'm make believe
Ok, good to hear.
Old Mar 12, 2008 | 02:02 AM
themysteryman83's Avatar
ORIGINAL: doadea
ORIGINAL: cincyTT
Did you do the rears as well? I know what you mean about the dust. It was the primary reason I switched to ceramics.
moluren
Jun 11, 2015 10:17 AM
audia6min
Aug 23, 2011 12:47 PM
Kealoha3
May 25, 2010 03:11 PM
rsonistxl
Jun 23, 2009 11:49 AM
rink2rink
Oct 7, 2006 11:19 PM
