signals lights do not flash/solid
This post should help
Try replacing the hazard light relay first. turn signals share the same relay. just did mine a few days ago. You can get it from world impex for 58 dollars. sku nunber:934277 or p/n <br>8N0 941 509 A. There is write up on audiworld: <A HREF="http://forums.audiworld.com/tt/msgs/1193292.phtml" TARGET="_blank">http://forums.audiworld.com/tt/msgs/1193292.phtml</A><p>If it doesn't fix it, then your turn signal stalk needs to be replaced.
