so... how hard is it to swap out a k03s for another k03s?
Old Jan 27, 2009 | 01:50 PM
  #21
chosos's Avatar
forgive my ignorance on this topic, but what is the difference? I thought the K03 was a direct swap for the k03s? are the mounting points different sizes?
Old Jan 27, 2009 | 02:10 PM
  #22
cincyTT's Avatar
I'm make believe
Both the housings are different on the longitude (A4/Passat) vs transverse (TT, gti, jetta) plateform. The ko3 is the same as the ko3s but the ko3 has 11blade compressor wheel and doesnt have that canister on the compressor outlet.
Old Jan 27, 2009 | 02:16 PM
  #23
cincyTT's Avatar
I'm make believe
ko3s top, ko3 bottom
Old Jan 27, 2009 | 02:56 PM
  #24
chosos's Avatar
thanks, thats is a perfect picture! so the housing is different, and I need a housing from a transverse engine.
Alternately, if you had a manifold made to fit the k03 from the passat, would that work too or are all the angles for the pipes wrong?? (I'm trying to better understand this.)
Also, is it possible to swap the housing from one turbo to use it on another?
I'm trying to figure out why its such a pain to use a k03 from a passat, when someone else can use an aftermarket garret turbo (or is that housing specific to transverse engines?)
sorry for all the questions. ;-)
Old Jan 27, 2009 | 03:11 PM
  #25
cincyTT's Avatar
I'm make believe
The housings will swap if you have the same size wheel housings.
You cant use that setup since the manifold puts the turbo on the other side (right vs left side of engine) and both housings are completly different
This is how a longitude setup is
verses a transverse housing
you can see the outlet on the trasverse is down vs to the side on the longitude.
If you didnt know, a transverse engine goes like this
rear of car
1-2-3-4
front of car
and a longitude engine goes like this
rear of car
front of car
Subarashī Kao
Oct 24, 2012 10:54 PM
EpicWin
Nov 11, 2008 02:10 AM
erikas3
Jul 17, 2008 01:51 PM
mnsirx
Aug 18, 2007 12:40 AM
mnsirx
Aug 17, 2007 11:03 PM
