squeeks suck
Old Nov 14, 2005 | 02:10 PM
RussTT's Avatar
Default squeeks suck
My audi now has a bunch of annoying squeeks and in turns it sounds like my wheels are falling off... loud turning sqeeks and alot of rattle I was wondering if anyone else is having squeek problems with their TT?
Old Nov 14, 2005 | 02:36 PM
jukeit's Avatar
Default RE: squeeks suck
Squeeks are probably your control arm bushings. I have them and just live with them. I just turn up the stereo.
A few weeks ago I noticed my steering would make a sound like Chubaca (sp?). Found my power steering fluid was low. I flushed the fluid and found the leak (bad hose clamp). That took care of my steering noise. Not sure if that is what your problem is, but it would be worth checking.
Old Nov 14, 2005 | 05:34 PM
dankhound's Avatar
Sway bar bushing squeek pretty often too. You can try disconnecting the end links and rotating it. If they squeak theyre bad.
Old Nov 14, 2005 | 07:16 PM
rodrigueza7's Avatar
Yeah, I have the same noise on my TT. They don't make a single noise when going straight but when making u turns or sharp left and right turns it does. It sounds like the tires are rubbing against something what's even funnier is that it doesn't happen all the time. I do know that the noise is in the back but that's about it. I also have a very annoying squeek on the driver side window. No matter if it is going up or down it squeeks all the way and it is a little embarrasing when you have a lady next to you.....if you know what I mean.....
Old Nov 15, 2005 | 12:07 PM
RussTT's Avatar
Well i guess this means its time for new suspension and brake upgrades. that should take care of the squeeking
Old Nov 16, 2005 | 04:14 AM
dankhound's Avatar
Hey russtt i misread your post. You may have bad wheel bearings. Is the noise louder on the opposite side of the way your turning? IE. Turn left, noise on right. Squeaks and rattles are pretty common on the tt's. One quick check is the cargo cover in the rear. Try removing that and see if any noises go away.
rodrigueza7 clean the seals all around the window really good. If that doesnt get rid of the noise use a rubber lubricant/conditioner on the seals.
Old Nov 16, 2005 | 11:29 AM
Dankhound: I'll try cleaning the rubber seals on the side of the glass and see what happens. About the rubber lubricant, I thought about it but never did it cause I thought the oily film was going to collect more dust than it already had.
About the squeek when turning, in my case is not really a squeek is more like a grinding noise that's why I thought the tires were rubbing on a plastic or something. I have to get under the car and see what's up.
Old Nov 16, 2005 | 06:11 PM
dankhound's Avatar
The wheel bearings do make a grinding noise. The key is that it does it when you turn. Which leads me toward wheel bearings? One bad thing about the lubricant is that it will spear on the windows for a while. I leave it for a week or so while periodically operating window. Then wipe everything down good.
myriadshalaks
Dec 13, 2010 11:09 PM
jwangen
Sep 3, 2010 07:42 AM
.clipse
Dec 29, 2008 05:07 PM
brent07
Feb 2, 2006 11:07 PM
