Starter needs to be replaced....how much? DIY?
Old Nov 26, 2006 | 06:21 PM
techbod's Avatar
Default RE: Starter needs to be replaced....how much? DIY?
not an easy one here you need to undo the bolts on the starter motor a little then spray in there, saying that it would be the same to remove it and service it.
not sure if you clutch has a service opening for locking the fly wheel for changing the timing belt but if it has that's a good area to spray into
Old Nov 26, 2006 | 10:05 PM
diehlryan's Avatar
is it a high pitched squeal? my car does that too. only on cold starts though. someone told me it was some sort of fan starting. others say a belt.
what are other peoples opinions on this?
Old Nov 26, 2006 | 11:22 PM
bmwtoaudi's Avatar
I'm going to take it to the dealer when i get paid....i dont want them to **** me to hard ...
Old Nov 27, 2006 | 12:06 AM
MeanAudiA6's Avatar
ORIGINAL: avant80@2.6
what would you use to lock the flywheel? i know of the check valve you speak of. its a to the left of the gear selector shaft and linkage. it has a rubber pull-plug you have to pull out then you can see the flywheel. i've looked at the timing belt job instructions and it doesnt say anything about that check valve(opening) but i can see how it would help keep TOP DEAD CENTER.
Old Nov 29, 2006 | 11:21 PM
MeanAudiA6's Avatar
hey avant you there?
ratlook13
Oct 24, 2011 04:49 PM
im so audi5000
May 2, 2009 11:23 PM
dan4g63
Jan 31, 2007 03:27 AM
vitonxl
Oct 11, 2005 10:28 AM
