Stripped Haldex drain plug....
So i went to do the haldex oil/filter change, and teh drain plug as a pain to get off. We eventually got it off, but along with it came some thread from the haldex unit itself.
When putting in the new plug, it would just spin, the holes were stripped. I ended up not using the washer, and the plug held in (had to get car off friends lift).
The plug w/o washer is in now, its not leaking, but im sure it will eventally, and I dont want to know what happens if the unit runs dry!!!
Anyways, what is the recommended fix to address this? Tap the drain hole to the next size and buy a bigger plug? Helicoil? or just take it to the stealership?
Thanks!
Thanks!
my vote is for a helicoil. Probably one of the best things you can do when threading into aluminum. I have more trouble with aluminum threaded parts than anything else in the garage.
werkwitdis
Jun 4, 2006 02:07 AM
