Temp Light Acting Up
Old Nov 5, 2009 | 07:53 PM
ttrex's Avatar
Default Temp Light Acting Up
I have a 2004 1.8L Roadster. 40000 miles. The temp light often comes on right when I start up the car. If I turn it off and start it up again, it is fine. It has never come on while driving. Bad sensor?
Old Nov 5, 2009 | 08:00 PM
warranty225cpe's Avatar
Sounds like it. Make sure your CTS is plugged in all the way, and that there's no gunk/corrosion on the connector.
Old Nov 6, 2009 | 02:46 PM
achTTung's Avatar
temp warning light? huh? Not the low coolant warning? Add a bit of water/coolant, see what happens.
Old Nov 6, 2009 | 04:29 PM
Lyman_T's Avatar
What does the manual say about it? What does Service say about it? I'm guessing it is doing a self-check, and it's normal, since you didn't say this has just started occuring.
Old Nov 6, 2009 | 04:31 PM
achTTung's Avatar
trip computer should flash 'OK', check engine, airbag, abs idiot lights flash on for a second every time you start it. Shouldnt be any temp type stuff.
The Bub
Oct 8, 2012 09:52 AM
toboater
Oct 26, 2010 12:15 PM
Armenian
Apr 1, 2009 01:42 AM
daghstdrummer
Jun 7, 2007 01:11 PM
rezurxtion
Feb 1, 2006 06:11 PM
