traction lights
Old Aug 1, 2006 | 04:10 AM
intake's Avatar
Default traction lights
Every so often my abs and traction lights come on together but they don't stay in memory.Once you turn off the car they go away and come back once i been driving for a bit ,but once you cycle the key it goes away again. Does anybody else have this problem or fix ?
Old Aug 1, 2006 | 09:37 PM
225tt's Avatar
Default RE: traction lights
It happend to me once when I was driving but that is about it. I just turned off the car and then turned it back on and it went away and I havent had it happen to me again. Sry that's all I know.
Old Aug 1, 2006 | 11:48 PM
achTTung's Avatar
you can try cleaning the abs sensors, that might help. Gotta take the brake rotor off, and you'll see a slotted disk, theres a small magnetic sensor that reads the spaces in the disk to tell how fast the wheel is moving. The magnet picks up road debris, and overtime may get poor readings. Good blast with shop air cleans them well.
worth doing once in a while, even if its not the fix.
Old Aug 3, 2006 | 01:11 AM
Spdrcr7882's Avatar
Ahwile back my traction control light came on, then when I turned the car off it went away, but now it usually comes on after about a minute of driving and stays on? Would cleaning that sensor help me aswell?
Justin
Old Aug 4, 2006 | 11:08 PM
achTTung's Avatar
like i said, it doesn't hurt to make sure its clean. Theres no way to tell exactly whats wrong with your car without scanning it though, so I really couldn't tell you if its going to fix it..
Old Aug 6, 2006 | 12:11 AM
sullivan2's Avatar
hey if it is not debris on the sensor,what is the next fix?I herd it may be a brake resistor?Is that true and is it easy to fix?/sully.
Old Aug 6, 2006 | 06:18 PM
achTTung's Avatar
not sure, not even sure what a brake resistor is. ??
Kevin Artz
Dec 29, 2011 10:41 PM
obryan44
Nov 5, 2011 10:20 AM
DÌEGØs AÜD!CTIØN
Jan 22, 2009 07:12 PM
shelbyturbo
Jan 16, 2008 10:41 AM
Adam in CO
Nov 1, 2007 09:11 AM
