TT wont start
Old Aug 20, 2011 | 01:16 PM
jonshearer23's Avatar
Unhappy TT wont start
I have a 2002 TT 1.8L FWD.
The gauges in the instrument cluster have been crazy since right after i bought the car, sometimes they would all work just fine, sometimes lights and gauges would flick back and forth for awhile and then work and sometimes whole cluster would go out. If they went out i would disconnect/reconnect battery cable and then they would work for awhile.
Past month or so the car has been randomlly shutting off while driving, the battery light would come on as well as the immobilizer light. I would just coast to the side of the road. Car would start up and die after couple of seconds. I found that if i disconnected the ground wire on the battery for any where from few seconds to few minutes and reconnecting the car would start up just fine. Had become more and more frequent. Finally the other day car wouldnt start back up at all, even after taking cable off for few hours, leaving key in ignition for awhile, and various other tips that I saw online. Read that it was probably a problem somewhere with the immobilizer on the car. I only have the one key for the car(the one with out the fob). Purchased one of the Vag-Com cables with the software online, to see if i could solve the problem on my own. I saw the fault codes for the Start blocked by Immobilizer(17978) and Key Unauthorized intermitent(01176). Thought about purchasing Vag Tacho and try and reprogramm my key. But im not sure if its the key that just lost its programming or its a problem with the immobilizer. If someone could take a look at the fault codes below any help would be greatly appreicated.
VAG-COM Version: Release 409.1-S
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01: Engine
Controller: 8N0 906 018 AL
Component: 1.8L R4/5VT G 0004
Coding: 07500
Shop #: WSC 01236
TRUSC28N421005801 AUZ5Z0A7010038
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
Readiness: 0110 1101
Address 03: ABS Brakes
Controller: 8N0 907 379 D
Component: ESP 20 CAN V006
Coding: 23049
Shop #: WSC 01236
No fault code found.
Control Module Part Number: 8N0 820 043 A
Component and/or Version: TT-KLIMAVOLLAUTOMAT D03
Software Coding: 00140
Work Shop Code: WSC 01236
5 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to B+
00604 - Shareware Version. To Decode all DTCs
30-10 - Please Register/Activate - Intermittent
01273 - Shareware Version. To Decode all DTCs
17-10 - Please Register/Activate - Intermittent
01206 - Signal for Duration of Ignition: OFF
27-10 - Implausible Signal - Intermittent
01582 - Shareware Version. To Decode all DTCs
Control Module Part Number: 8N1 920 980
Component and/or Version: KOMBI+WEGFAHRS. M73 D02
Software Coding: 02244
Work Shop Code: WSC 65535
Additional Info: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Additional Info: 8N1920980 KOMBI+WEGFAHRS. M73 D02
5 Faults Found:
01176 - Key
65-10 - Unauthorized - Intermittent
01179 - Shareware Version. To Decode all DTCs
35-00 - Please Register/Activate
01314 - Shareware Version. To Decode all DTCs
49-10 - Please Register/Activate - Intermittent
01304 - Radio
49-00 - No Communications
01305 - Shareware Version. To Decode all DTCs
37-00 - Please Register/Activate
Control Module Part Number: 8N8 951 177
Component and/or Version: Innenraumueberw. D09
Software Coding: 00001
Work Shop Code: WSC 00000
2 Faults Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
35-00 - -
01462 - Shareware Version. To Decode all DTCs
53-00 - Please Register/Activate
Dylan Cure
Sep 4, 2012 04:21 AM
zslatcher
Oct 24, 2011 06:15 AM
Billydakid
Oct 29, 2010 02:40 AM
