turbo troubles, please help
Old Apr 30, 2008 | 08:51 PM
Mobius97's Avatar
Default RE: turbo troubles, please help
Could this be bad sparkplugs???? It sure does sound like it...jamming on the throttle and it starts cutting out. An easy $15 fix if it is. If the car drives fine under light acceleration but bogs or hesitates when you jam on it...you can feel and hear it...plugs or packs. I would start with plugs.
Old Apr 30, 2008 | 10:10 PM
achTTung's Avatar
ditto on the plugs.
Unless you're driving on a volcano or something, I've never heard of heat soak being so debilitating for normal road driving, ESPECIALLY for a stock car. Only exception I can think of would be a totally caked over intercooler. Just like a radiator, it doesn't hurt to make sure the front of it isn't full of bugs/road debris that could reduce airflow thru it.
Old May 1, 2008 | 02:54 PM
cincyTT's Avatar
I'm make believe
If it was the plugs it would be on ALL pulls, not after the car had time to heat up. Also, the temp is changing and this would be very noticeable for a newish turbo driver. Plus, if its stock, there is no need to gap down the plugs
Old May 1, 2008 | 02:56 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: ttdude
water/ meth injection can range a lot, kits are sold for 400, But you can DIY* by using your window washer reservoir and buying the necessary pumps and hoses and injectors.
*only recommended if you live somewhere without snow or a lot of rain, like Arizona.
You can get a kit for under $300. Also, where you live has nothing to do with it. The turbo still makes heat and the water will still cool the iat's lower than a fmic alone. Also you will still see 100+ oct year round. Its perfect for all climates and locations
Old May 1, 2008 | 04:30 PM
ouTTie914's Avatar
I think he was talking about using the washer reservoir as the tank for water/meth injection.
Seeing as if you lived in a area with a lot of rain/snow you wouldn't be able to clean the windshield/headlights.
Old May 1, 2008 | 08:54 PM
Mobius97's Avatar
ORIGINAL: cincyTT
Cincy you know your **** and can easily school me but real world experience works wonders for knowledge. I have to disagreee with you here. When my plugs needed to be changed out it was an intermintent thing. It did NOT happen on all pulls or during all drives. Sometimes the car would drive and behave just fine then all the sudden hesitation and stuttering and would do this about 15 PSI. I dealt with it for three days over my Christmas vacation. I eventually solved the problem by replacing the plugs. No trouble since!
I understande heat soak. Hell I've driven my TT thru the Eastern WA desert in the middle of summer in 100 degree weather before I had my FM. Yeah there was some loss in power but by no means to what he is describing.
To back what I am saying here is the original thread I made where your lovely insite helped me!!
https://www.audiforums.com/m_754205/tm.htm
Old May 3, 2008 | 03:20 PM
cincyTT's Avatar
I'm make believe
What i am saying is that he would experience the misfires (if there was any) from the time he starts the cars and drives it. He doesnt experience the loss of power until heatsoak can kick in. plus there is not light flashing on his cluster.
Also i bet if he vagged his car he would see very high iat's when its running bad as opposed to normal. Also would bet there was no misfire codes. You could be right, but thats not what im getting from his discription
elizedge
Sep 12, 2013 11:48 PM
Deathgen
May 18, 2009 09:05 AM
kp99audiA4
Dec 2, 2008 01:18 AM
Cortez2306
Feb 9, 2008 03:04 PM
tib4me
Aug 25, 2007 02:26 AM
