Turbosmart MBC
Old May 19, 2008 | 10:18 PM
exTTreme's Avatar
Default Turbosmart MBC
Today my turbosmart MBC arrived in the mail (I bought it off vwvortex classifieds) after staring at the pictures in Cincy's diode mod post I went out and hooked it up after a few trips down the street and back I got it set at a 16 PSI spike I went over 14 on accident but my question is shouldnt the ECU go into limp mode? and then question #2 for anyone who knows about or is running the turbosmart MBC is the allen key screw on the side for adjusting the boost also?
Getting the boost I lost from the oversized intercooler backmakes me very happy
Old May 19, 2008 | 11:21 PM
Dfminc's Avatar
Default RE: Turbosmart MBC
My boost gauge tells me I get 16 psi spikes stock if that helps.
Old May 20, 2008 | 03:36 AM
Skipponator's Avatar
Is this the in-cabin or just plain under hood MBC? Don't touch the screw, just use the know. The in-cabin will not work in our cars, it will max at 19psi. The underhood works well, I had mine set at 22 or so, but only ran in for a week while waiting for the dual stage which I love! Flip a switch, and whoosh your gone!Your really should not see any spike with a MBC. I had a spike with my N75 but as soon as I put an MBC in, no spike, just peak setting, and the hold.
Old May 20, 2008 | 05:11 AM
exTTreme's Avatar
It's the regular under hood style one it still has a spike just tapers down much slower now
Old May 20, 2008 | 10:17 AM
ouTTie914's Avatar
The **** with thehex key controls the ball and spring (course) setting.
The **** that you can turn freely controls the bleed (fine) setting.
Turbo XS HPBCFAQ:Install/how to adjust;http://www.turboxs.com/faq/turboxshigh.htm
Old May 20, 2008 | 12:31 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: ouTTie914
write country, wrong company.
The allen bolt just tightens the **** so you cant adjust it more. A bleed mbc will limit spiking since it constantly bleeds off the boost pressure unlike a b&s which holds all the pressure until the certain psi is reached and the ball lifts high enough for the pressure to pass and reach the wastegate.
Old May 20, 2008 | 06:39 PM
Mobius97's Avatar
Mine likes to hold steady about 21 but will tapper down. I do get the occasional boost creep to 24 butI quickly back off when I catch it. This happenswhen cruising thru the Cascade mountains in the Seattle areaon I90 doing some fun speeds around 75-85Mph.
Old May 20, 2008 | 07:28 PM
ouTTie914's Avatar
Oops!
You can download the instructions here: http://www.turbosmartonline.com/index.php?s=downloads
Old May 20, 2008 | 07:32 PM
cincyTT's Avatar
I'm make believe
He already has it installed and tuned.
Dont think a minor spike over will set you into limp on a high load situation
drev500@aol.com
Aug 30, 2010 06:35 PM
Blacky 225
Nov 30, 2008 12:17 AM
NICEMSP
May 18, 2008 03:43 PM
Mya4T
Jun 28, 2007 12:53 AM
deuce$$
Aug 5, 2005 05:51 PM
