Unisettings, lemmiwinks, and boost
Old May 23, 2008 | 08:46 PM
Dfminc's Avatar
Default Unisettings, lemmiwinks, and boost
So I have a 225 that I've done the diode and mbc on and I was wondering if unisettings would be helpful for making more power etc. What are the uses of unisettings in general? The one I have heard of is increasing timing with water/meth. Any info would be appreciated.
Old May 23, 2008 | 08:50 PM
cincyTT's Avatar
I'm make believe
Default RE: Unisettings, lemmiwinks, and boost
It will let you dial in your a/f and change timing. This is the unisettings and all you can change
Old May 23, 2008 | 08:52 PM
Dfminc's Avatar
Thanks. So for my particular application it wouldn't be useful?
Old May 23, 2008 | 09:05 PM
cincyTT's Avatar
I'm make believe
Check your a/f and timing and if you need +/- fuel or can add timing, do it
Old May 23, 2008 | 09:09 PM
Dfminc's Avatar
I have a 02 225 with the nbo2 so the readings I get won't be particularly useful? (get aem?)
Old May 23, 2008 | 09:46 PM
cincyTT's Avatar
I'm make believe
a wbo2 is the only way to get accurate results. Taking the nbo2 will give you some idea, but not enough for any major tuning. FOr what you are doing, the nb should be fine
Old May 23, 2008 | 09:54 PM
Dfminc's Avatar
thanks for the info
Old May 24, 2008 | 12:37 PM
dynedta's Avatar
just alil info which i will make a post about, but i found on the 225 the 4.3v diode isnt good enough, instead buy a clamp box from kingclamp.com its completely adjustable i had some stubbling issues as well as poor throttle response. now with the box it seems to have all been solved
Old May 24, 2008 | 01:37 PM
Dfminc's Avatar
I don't understand how the diode would be directly related to poor throttle response and stumbling or how a adjustable voltage clamp would remedy that situation.
chris120391
Nov 3, 2010 11:49 AM
chris120391
Oct 29, 2010 02:53 PM
AudiCross
Apr 17, 2008 08:17 PM
B5 owns
Mar 26, 2008 12:47 AM
Don R
Apr 24, 2007 01:55 AM
