vibration when right
Old Apr 25, 2008 | 11:59 PM
kevintt's Avatar
Default vibration when right
It seems when im in either fourth or fifth gear and over 50 and onl turning right or steering right i feel a vibration in the floor. For a second i thought maybe ball joints of tie rod's. maybe even bad balance in the front right tire. I recently had my timing belt done and new tires put on wth in the last 5000 miles but just noticed this new vibration. I was wondering if maybe a bad motor mount could have something to do. Im not ase but i got a great vast understanding and ill appriciate any help thanks.
01 audi tt, AWP 180 FWD.
Old Apr 26, 2008 | 12:32 AM
Murderface's Avatar
Default RE: vibration when right
Could be something with power steering. Check weheel balance/alignment...motor mounts tend to go too. Mine are shot and make a vibration around 2200 RPM.
Old Apr 26, 2008 | 01:11 PM
Mobius97's Avatar
When this happened to me my axle fell off. A tight right turn I would feel a vibration from the floor of the car. Not saying that is what your issue is but what you are describing was very similar to my situation.
Old Apr 26, 2008 | 02:15 PM
rayveedub's Avatar
check the motor mounts are tightened up correctly, if they are then i would blame tires.
Old Feb 5, 2010 | 12:25 PM
RenoRains's Avatar
If its like my 02 with over 120k miles....its probably the front control arm bushing...
Mnew
Jan 22, 2012 12:06 PM
Bluv
Oct 5, 2009 05:43 PM
Boostmore
Aug 25, 2009 11:03 AM
Fernandus
May 31, 2008 08:16 PM
aabbyen
Aug 18, 2007 04:07 PM
