W/M install complete. (Stage 2 MAF Kit) *** All is not Lost ***
Old Oct 9, 2007 | 02:51 PM
  #101
TTsteve's Avatar
Default RE: w/m install in progress. questions...
So that was without adjusting timing or boost? 20 extra HP would be nice, I think I have enough torque on the car now but a few more is OK.
Old Oct 9, 2007 | 02:56 PM
  #102
cincyTT's Avatar
I'm make believe
Just did some searching in the 2.0T forum and they did bump timing a little. Read here steve
Old Oct 9, 2007 | 04:50 PM
  #103
TTsteve's Avatar
Thanks.
Old Oct 9, 2007 | 05:03 PM
  #104
eliTTe's Avatar
so whats the difference between using a alcohol mixture or methanol mixture?
Old Oct 9, 2007 | 05:13 PM
  #105
Ergokinetics's Avatar
Would w/m noticeably reduce engine temps during prolonged spirited driving (aka track days)? Any disadvantages?
Old Oct 9, 2007 | 05:16 PM
  #106
cincyTT's Avatar
I'm make believe
ORIGINAL: eliTTe
Im sure there is. What, i dont know. But Evo guys call it alky injection. Might go over there and look later
Old Oct 9, 2007 | 05:47 PM
  #107
TTsteve's Avatar
ORIGINAL: Ergokinetics
Thats what I really wanted it for, that way I wouldnt have to upgrade the IC. Plus I was hoping it would add alittle extra power without timing, that way if it ran out the engine would still be fine. It gets hot here in GA during the summer (100+) and Im sure the Ics are getting heat soaked. I guess I will have to see if GIAC has or will get a race program for the 2.0T and get that to run on the w/m kit with 93 oct gas.
Old Oct 9, 2007 | 06:20 PM
  #108
cincyTT's Avatar
I'm make believe
it can take the place of a upgraded ic. Problem with us 1.8t people is that the ic are actually a big restriction unlike you 2.0T people. The stock single smic has like a 2psi pressure drop do to it unable to handle the increase of flow of a chip.
Old Oct 9, 2007 | 08:25 PM
  #109
JettaRedII's Avatar
ORIGINAL: eliTTe
Ummm, methanol is alcohol. Just don't drink it.
Old Oct 9, 2007 | 08:55 PM
  #110
achTTung's Avatar
Methanol, Ethanol, Propanol, Butanol,all alcohols, doesn't mean they're the same.
Each one is chemically different, and the more you add to the chain, the more variations there are, so before you go lumping them all together, make note of this.
-Without really looking into it, I'd guess 'alky injection' is a dumbed down term for water/meth?
--Heres some semi-related reading to look over sometime you're bored.
http://journeytoforever.org/biofuel_...manual1-2.html
that journeytoforever site I came across last fall looking for designs for a waste oil furnace. tons of fun little 'projects' i'd like to try sometime.
