What is the code for my turbo?
Old Jan 3, 2009 | 05:34 PM
audi_tt_4u's Avatar
Default What is the code for my turbo?
I have a 2000 Audi TT 180 hp... What is the code for that turbo and I wanted to upgrade to the 225 hp turbo.. Will that swap make a difference for the money? I am looking for the code for my turbo and also the code to the 225hp turbo just incase I decide to buy the 225hp turbo. Thanks Guys..
Ps.. I have searched the site and no luck on the code... Thanks
Old Jan 3, 2009 | 05:37 PM
cincyTT's Avatar
I'm make believe
Was the faq part of the search? They are not direct swaps, you need everything from the 225: turbo, manifold, injectors, etc.
Old Jan 3, 2009 | 05:40 PM
audi_tt_4u's Avatar
The part of my search was "oem turbo" "stock turbo" "TT turbo" I think you are picking up that I was searching for.
Old Jan 3, 2009 | 05:41 PM
audi_tt_4u's Avatar
What swap would be worth the money? If there is one....
Old Jan 3, 2009 | 05:58 PM
lennyauditt's Avatar
I don't think its worth the money. Just buy a chip. If you don't have one already
If you want to swop turbos just go for a BT(big turbo) set up . Might be a little more $$$ but more practical. IMO
Old Jan 3, 2009 | 07:13 PM
audi_tt_4u's Avatar
Is chip expensive to put in? I have never chipped a car before.. What all does the chip do? More fuel and boost?
Old Jan 3, 2009 | 07:24 PM
cincyTT's Avatar
I'm make believe
Its a remap. They increase the psi and timing with fueling to match. It use to be an actual chip in the ecu, but now they are flashed. Most cost $500 and you do nothing but bring it to a dealer.
Old Jan 3, 2009 | 07:29 PM
audi_tt_4u's Avatar
500 is a grip of cash to be throwing down.. How was the results 4 u?
Old Jan 3, 2009 | 07:35 PM
Better then wasting your money on a K04 turbo. Check out the numbers on APR.
http://www.goapr.com/Audi/
Old Jan 3, 2009 | 08:54 PM
cincyTT's Avatar
I'm make believe
see below
