what is the housing with the green temp sensor called?
Old Mar 28, 2008 | 11:52 PM
carguytt987's Avatar
Default what is the housing with the green temp sensor called?
well i found my coolant leak, it is from the housing that contains the green temp sensor, the o ring got oil on it from the valve cover leaking And is is very soft and was leaking soo, i need to do the valve cover gasket along with the timing belt.... what is this called so i can get the part ,,, thanks guys
Old Mar 29, 2008 | 06:02 AM
beachchair's Avatar
Default RE: what is the housing with the green temp sensor called?
I believe this may be what you a looking for:
Coolant Temperature Sensor (part 059-919-501-A)? The new ones are green.
Old Mar 29, 2008 | 01:52 PM
MeanAudiA6's Avatar
here Febi - Coolant Hose Flange ES#2470
http://www.ecstuning.com/stage/edpd/...ategory=Engine
Murph's law
B7 Models
Jan 24, 2015 10:29 AM
djjuice
Dec 9, 2010 10:08 PM
DurTTy
May 24, 2008 01:38 PM
moeron7
Mar 3, 2007 01:56 AM
pliddy
Sep 4, 2004 06:40 AM
