what is the housing with the green temp sensor called?
well i found my coolant leak, it is from the housing that contains the green temp sensor, the o ring got oil on it from the valve cover leaking And is is very soft and was leaking soo, i need to do the valve cover gasket along with the timing belt.... what is this called so i can get the part ,,, thanks guys
