Where is the filler plug?
Old Feb 25, 2012 | 12:08 PM
rowesouth's Avatar
Default Where is the filler plug?
2003 TT with 180hp motor, Tiptronic auto trans
After having a bit of trans trouble, and because several posters mentioned replacing fluid & filter, i ordered a kit from Blauparts. Now I've got it but I'm stuck - cant find the filler plug on the trans.
An old post here indicated the drain port & fill port are the same - but I'm not buying that because there are separate parts in this kit for each.
I'm not draining this thing until i _know_ I can refill it - so can anyone here give me a clue as to where the filler plug is located?
Old Feb 25, 2012 | 12:35 PM
M5S5's Avatar
Tech Certified
Fill plug is the transmission pan. Need special filling tool for the job.
Old Feb 25, 2012 | 01:06 PM
rowesouth's Avatar
I'm looking at the pan - there's only one plug - which has to be the drain plug, as it's different than the replacement fill plug that came in the kit. I need to find the fill plug.
Old Feb 25, 2012 | 02:46 PM
M5S5's Avatar
Tech Certified
It might be worth buying the info from Alldata. it does show a separate drain plug but i usually just pull the pan down & drain into oil drain.
The plug in the pan is the inspection hole for the fluid & in most cases the same spot where the fluid is filled into. It also involves monitoring transmission temperature with a scan tool that has the capability to read transmission data(Vag-Com is my tool of choice most of the time).
One more thing is that when transmission fluid levels are checked the vehicle Must Be level!
Pilipenko
Nov 28, 2011 10:06 AM
ee99ee
Oct 12, 2011 12:28 PM
hottubbrad
Dec 16, 2009 11:24 PM
teck101
Apr 8, 2008 11:43 AM
werkwitdis
Jun 4, 2006 02:07 AM
