WTF is burning???
Old Jun 2, 2008 | 12:05 AM
Thepianist15's Avatar
Default WTF is burning???
Ok, after finally fixing some of the problems with my 225TT, I had a little fun in the beautiful weather today. After about 30 minuites of driving hard, I stopped and put the hood up to investigate a burning smell. It wasn't huge, but there was noticeable smoke coming out from the heat shielding wrapped around some of the hoses around the turbo. I figured it was a sheild that was broken and a hose was melting, but after everything cooled, I removed the shields and there was no damage. Possible a gasket leak around the turbo????
The smoke was white if that means anything. I need an answer before something gets really messed up. Any ideas????
Thanks for any help
Nick
Old Jun 2, 2008 | 12:10 AM
Default RE: WTF is burning???
My only though was oil dripping out of the turbo on to the exhaust manifold right below. Not sure if that makes sense, but its a thought. I've checked oil levels and they are perfectly normal.
Old Jun 2, 2008 | 12:14 AM
achTTung's Avatar
what problems were worked on before?
I know I get my greasy mits everywhere when Im under the hood, and it take a little time to burn my fingerprints back off of hot parts.
Old Jun 2, 2008 | 02:16 AM
I recently installed a 42 Draft Designes down pipe about 3 weeks ago. I also just installed a new vaccume hose. I orgionally thought that it was just left over oil drippings from the work and from the oil change, but it would have burned off by now. The new hose i just installed isn't anywhere near where the smoke is coming out.
Another problem to be addressed if they are possible linked. Despite the new hose, there is still a loud hissing/ air rushing noise when the turbo engagues. But soon after the engine gets hot, this hissing noise goes away and the turbo seems like it is non-existant. In order of things that happen.....
1. Drive car hard for about half hour
2. Hissing is prominent the hole time
3. About a half hour into driving, the burning smells comes with smoke, hissing stops, and the turbo is like nothing.
4. After a cool down, the turbo is back with full boost, but the hissing comes back.
I'm not sure if the burning and hissing are all linked together. A previous post suggested that a vaccume hose is broken under the intake manifold.
Thanks for the help.
Old Jun 2, 2008 | 09:01 AM
Wintermute's Avatar
D/p might be coming loose. Check with soapy water if any hoses you've played with lately have a leak or just not attached correctly.
fast euro
Aug 19, 2011 03:50 PM
krilleater
Mar 19, 2011 08:29 PM
gillen01
Feb 23, 2011 09:40 AM
Robsa4
Sep 23, 2006 03:02 PM
arctica3
Mar 21, 2006 01:37 PM
