$10,000 Service Estimate from Dealer? or should I try my luck somewhere else? [2001 A
Old Mar 3, 2016 | 04:17 AM
Timmy Reilly's Avatar
Default $10,000 Service Estimate from Dealer? or should I try my luck somewhere else? [2001 A
I received this service estimate for my 2001 Audi A4 at a dealership after a check engine light went on and I needed a new key programmed.
What do you think?
Additional items noticed during inspection:
  • Valve cover & camshaft tensioner gaskets leaking ($1375)
  • Engine mounts collapsed ($1110)
  • Pollen filter dirty ($95)
  • Crankcase breather hose leaking ($475)
  • Coolant reservoir leaking ($190)
  • High pressure power steering hose leaking ($610)
  • Both catalytic converters failed ($3600)
  • Both left & right front outer cv boots torn ($495 each)
  • All 4 door speakers ($1450)
Plus original estimate of $398.45 (for oil change, check engine light diagnosis, key programming, and key battery)
Should I drop the coin?
Take it to different place?
Find a new car?
My current plan is to call around tomorrow for some more estimates.
Any ideas, experience, wisdom to share?
Old Mar 3, 2016 | 08:24 AM
A4TurboGuy's Avatar
Holy ****!
He might as well just rob you with a gun. That's so ******* ridiculous, it would be funny if it weren't so outrageous.
Stay the hell away from that!
Old Mar 3, 2016 | 10:34 AM
MetalMan's Avatar
Yeah, that's HORRENDOUS. Take it somewhere else and get a second opinion.
Old Mar 3, 2016 | 04:13 PM
markymarc's Avatar
What do you think?
Find a new car?
ummm...I'll do all that for some beers and you pay the parts....the only really dicey thing are the engine mounts, but those can be fixed as well....
Find a good, reputable INDY (independent) shop that works on German cars and has a great reputation.....bet you it may be at least half or less.....
Old Mar 3, 2016 | 04:33 PM
elduderino200's Avatar
Holy cow.
For reference, a new cabin filter (listed there at $95) is somewhere between $10 and $20. A new coolant tank (there at $190) is anywhere between $20 and $40. Crankcase breather hose (listed at $475) is between $20 and $60. Etc. Etc., you get the idea.
And that's even IF those things aren't working, which many of them are likely working just fine so a replacement isn't needed at ALL.
Take it to an indy shop and see what they say is wrong.
Old Mar 8, 2016 | 04:59 PM
redline380's Avatar
Legal Moderator
By far the worst estimate I have ever seen.
That $95 pollen filter may be the worst. At least the other stuff requires labor. Guessing I could have the filter done in 30 seconds, and that includes taking it out of the package.
Was this at an actually Audi dealership? If so, I would contact AOA with that BS.
joenelson7687
Nov 8, 2010 06:30 PM
kakashisan
Feb 25, 2008 09:47 PM
AudiA4Girly
Dec 17, 2007 02:43 PM
alias747
Apr 3, 2007 04:05 PM
