01 A4 shutting off help.
Old Aug 17, 2010 | 02:52 AM
Got01A4's Avatar
Default 01 A4 shutting off help.
Thanks
Old Aug 17, 2010 | 05:22 AM
99A4NOW's Avatar
Yes, pull the codes first. There's like a dozen things that might be causing this problem. If' you have a code for your MAF sensor replace that (it's still kinda expensive- $220). My car recently had a simular problem, ran okay then shut off. Was hard to restart then it would run fine for a couple miles, then shut off again. I'm told an easy way to check for a bad MAF is to just unplug it, so that might be a good easy place to start.
I don't know if there is a code that tells you you have a bad ECM, sounds like they're just throwing darts and guessing.
Old Aug 17, 2010 | 10:47 AM
Mike-2ptzero's Avatar
Buy a RossTech cable, well worth the cost.
Do you have a 1.8t or a 2.8 and what country are you in?
$3000 for a ECU or are they trying to sell you another 20001 A4?
Old Aug 17, 2010 | 10:57 AM
onepoint8tee's Avatar
Autozone or Advance will let you borrow their OBD2 scanner if you leave a deposit if you can't get your car there. I'm guessing your engine coolant temp sensor is bad. Your symptoms are spot on for it. Definitely find a new mechanic if they are trying to charge $3,000 for a new ecm, which is probably not the problem in the first place.
Old Aug 17, 2010 | 02:09 PM
Got01A4's Avatar
Thanks guys.
Old Aug 17, 2010 | 02:41 PM
You can always try to find someone close to you that has a Vagcom cable you can borrow. Plenty of people with them here in Socal.
Old Aug 17, 2010 | 03:21 PM
MiamiA4guy's Avatar
Wow 3g's for a new ECU For that you go and buy the AEM plug and play ECU system that cost like 1 to 2g lol you can find those ECU in crigslist or ebay for like less then 300 and you can install it your self.
Old Aug 20, 2010 | 09:29 PM
Got01A4's Avatar
Old Aug 21, 2010 | 01:15 AM
P1419
Looky^... I wasn't kidding! This is a $12 or so part at the dealer and easy DIY.
P1419
The ECM relay fault could be triggered by repeated sudden loss of power while driving. The ECM communicates with a few other control modules only if the engine is running. If this communication is interupted when the engine stalls, the ecm may think it has a power issue - relay.
The crankcase breather hose leaking isn't going to cause the car to stall.
Old Aug 21, 2010 | 01:40 AM
Got01A4's Avatar
