1.8 Running Hot
Old Feb 18, 2011 | 08:30 PM
StanTheCaddy's Avatar
Default 1.8 Running Hot
It goes up to the point in the picture after about 5-6 minutes of driving, will stay there for a few minutes before going back down to the middle for about a minute and then returning back up to the point in the picture.
When I got the car about 6 months ago the needle would never go beyond the middle, but I just got it back from the shop after searching for an oil leak they found a coolant leak and replaced the thermostat, gasket, water outlet, and bypass hoses. Coolant was drained and flushed.
It also smells like burning engine coolant after driving now.
Is it safe to drive with the gauge like that or should I get it looked at somewhere else?
Thanks
Old Feb 18, 2011 | 08:43 PM
Msnickbroderick's Avatar
Actual WIZARD
Safe: eh, your call. It's a gamble though.
My bet is they replaced the thermostat wrong. It goes in one way and one way only, but can be installed backwards or upside down. Also burping the system might help, not exactly sure
Old Feb 18, 2011 | 09:12 PM
ImTheDevil's Avatar
System needs to be burped. Do a search to find out how. That'll fix it.
Old Feb 18, 2011 | 09:14 PM
morpheous's Avatar
lmao@ needs to be burped...like our B5's are infants.
Old Feb 18, 2011 | 09:24 PM
turbo kraut's Avatar
Tech Guru
do you even know what they mean?
you never post anything worth while
Old Feb 19, 2011 | 11:11 AM
Sohcvtec1995's Avatar
if a shop just fixed it take it back to them and have them figure it out
Old Feb 19, 2011 | 01:27 PM
morpheous's Avatar
I agree with this advice,if a place did work to your Audi,and it causes an issue,they should have a warranty that will fix the issue that was caused by work they performed.
Old Feb 19, 2011 | 07:43 PM
foxracing4500's Avatar
deleted
Old Feb 19, 2011 | 09:30 PM
dont touch the car. you need to take it back to the place you got the repairs done at. if you mess with it then he can say it was due to something you touched.
Old Feb 19, 2011 | 09:58 PM
ImTheDevil's Avatar
Yeah let them deal with it. If they won't, burp it first, and check the t-stat if that doesn't do it. Burping it is less invasive and the symptom describes an air bubble. Do the easier work first.
pbrules10
Jul 1, 2012 06:07 AM
patrixx006
Mar 19, 2012 09:51 PM
A4 2000
Jul 15, 2011 10:40 PM
majite
Jul 26, 2010 09:49 AM
basher
Apr 30, 2009 10:47 AM
