1.8T 1999 Quattro Boost Problem
Old Oct 31, 2008 | 06:41 AM
netwave's Avatar
Default 1.8T 1999 Quattro Boost Problem
Please help,
ive a new KK03-04 turbo, Spec-r boost valve & universal fuel pressure regulator fitted!
When my car boosts near 10psi I get thrown forward & the cars boost drops? what starts off promising ends up failing!
I have read on other forums that this could be due to ECU overboost protection that may possibly be hacked by adding a static ground to fuel pump relay
Then I discovered the Zener mod with a 4.3v or 4.7volt on the map sensor wires. However Im not convinced my A4 had a map sensor fitted?
Is a map sensor ( manifold absolute pressure ) simular/ or the same as a "Barometric pressure sensor" which I think my car may have?
Im looking for a cheap mod that can be done to fix my problem to allow me to manually set my desired boost poss 15psi on the specR valve
Thanks
Old Oct 31, 2008 | 04:28 PM
TeeterTawter's Avatar
get proper programming?
Old Oct 31, 2008 | 04:49 PM
nmocci's Avatar
Your car doesnt have a map sensor. Its for either 2000+ or 2001+. You arent able to do the diode mod. Is that the stock turbo that was on the car? If its bigger your going to need a tune.
Old Oct 31, 2008 | 05:44 PM
A4speed's Avatar
MAP is on 2001+
Old Oct 31, 2008 | 07:41 PM
I have a 2000 and have a map sensor.^^^
Old Oct 31, 2008 | 08:02 PM
Jc61990's Avatar
are you chipped?, that would happen to me when i wasn't tuned and i would hit the psi limit for stock software. get a tune and you should be good.
Old Oct 31, 2008 | 09:38 PM
A4speed's Avatar
thanks for the correction, for some reason i thought the MAP sensor started on the AWM.
Bashawin
Jul 13, 2010 07:31 PM
Bashawin
Jun 24, 2010 10:53 AM
mirak
Feb 10, 2008 03:02 PM
titanmotor
Aug 8, 2005 09:25 PM
titanmotor
Aug 3, 2005 12:50 PM
