1.8t engine troubles!
Old Dec 9, 2012 | 06:55 PM
jman01a4's Avatar
Question 1.8t engine troubles!
i have an 2001 a4 1.8t and recently have been having a couple of issues. I noticed that there is always white smoke coming out of the exhaust, i have engine codes that say my secondary air pump is having issues. but the main issue is whenever i turn on the heater the entire cab smells like exhaust. what are the possible causes? any help would be appriciated.
Old Dec 9, 2012 | 07:31 PM
jonbonesjones's Avatar
Moderator
Clogged cats. Will cause the sai code and the exhaust smell. Not sure if it will cause white smoke.
Old Dec 10, 2012 | 09:16 AM
jman01a4's Avatar
i have always heard that clogged cats would result in a sulfur smell. is that not always the case? and how would clogged cats force exhaust into the cab only when the heater is going? thanx for the quick response!
Old Dec 10, 2012 | 09:26 AM
CCA4's Avatar
It's not that the exhaust is only leaking when the heater is on, but the inlet for the heater is right about where the exhaust leak would be. So everytime you have the heat on, it's sucking in the leaking exhaust.
Could also be a leak at/near your combi valve. That would cause the SAI code and a pretty large exhaust leak.
Old Dec 10, 2012 | 10:49 AM
Jchockey100's Avatar
your white smoke problem can be cause by a bad turbo, bad valve stem seals. the exhaust smell is most likely from clogged cats. and clogged cats will also cause the sai code and the exhaust smell.
Old Dec 10, 2012 | 11:02 AM
Moderator
Anyone else for clogged cats?
spaceboy3000
Dec 11, 2014 11:00 AM
tjfizz
Jan 20, 2014 09:47 AM
Cortez2306
Feb 9, 2008 03:04 PM
cdel112576
Nov 24, 2007 08:13 PM
newyorker
Oct 12, 2006 10:35 AM
