1996 audi a4 1,8t ignition problem
Old Sep 11, 2016 | 06:15 PM
audi 1,8tq's Avatar
Default 1996 audi a4 1,8t ignition problem
hi, my car only have spark on cylinder 2 its not the icm because it is removed, its not the coils or plugs. i have used vag com and read fault code, it showed that crank sensor faulty and cam sensor changed these and still no spark on cylinder 1,3,4.
i just bought the car and don`t know how this happend.
Old Sep 13, 2016 | 02:38 PM
elduderino200's Avatar
Why is the ICM removed?
Has anything you've done changed the outcome?
Try switching the injectors around.
Old Sep 13, 2016 | 07:56 PM
audi 1,8tq's Avatar
because i have 2,0l tfsi coils and then you don`t need that, nope the outcome hasn't changed, the injectors cant do so i don`t have spark?
Old Sep 16, 2016 | 04:29 PM
Possibly. Can you get a spark tester? I think they're only a few bucks or are available to rent from autozone/o'reilly's.
You're sure there are no more codes? Re check for codes and see if the cam sensor one is still there
Old Sep 16, 2016 | 08:54 PM
audi 1,8tq's Avatar
had a look at it today and coud not find anny fault codes and no wiring fault
Old Sep 17, 2016 | 01:46 PM
If you're sure it's no-spark as opposed to fuel, air, or compression, then it's got to be something with the plugs, coils, or electrical.
Old Nov 26, 2016 | 10:17 PM
audi 1,8tq's Avatar
now i have a new fault code on immobilizer low signal form key...
Launch
Jul 12, 2013 06:02 PM
Aidy Reihill
Jun 15, 2012 06:49 AM
chouinam
Jun 14, 2007 01:21 AM
