98 Audi A4 trouble
Old Oct 3, 2016 | 02:56 PM
Audikari's Avatar
Default 98 Audi A4 trouble
Started my car for 5 mins and it's starts smoking from under hood . I posted a video below to show where it's smoking from, my a/c doesn't blow cold any more or hot..coolant is full..somenone plese tell me what's wrong
Oh and FYI/ yesterday I took coolant resivior cap off and coolant started spluttering out.
Old Oct 3, 2016 | 03:19 PM
Mark C's Avatar
only things down there, besides a leaky valve cover dripping on the exhaust manifold, are the oil and coolant lines to the turbocharger. Whats the smoke smell like, oil or water?
Old Oct 3, 2016 | 05:59 PM
Audikari's Avatar
i couldn't get ahold of the smell..so u think it could be the valve leaking?
Old Oct 3, 2016 | 08:23 PM
Silverquattroa4's Avatar
Valve cover leaking
Old Nov 27, 2016 | 12:52 AM
Johnnyboy808's Avatar
How does engine temperature affect it? If it happens more when cold than hot, it's likely a valve cover gasket or small leak. It sounds like you've caught it early. If you haven't caught it early, it'll do it hot or cold. If it happens when both cold and hot, either valve cover gasket leaking onto your exhaust manifold or you have some sort of leak at the turbo; could be a return line. Try and rev it a bit. The turbo won't spool boost with no load (in neutral), but if the smoking gets worse, chances are that's a line on the turbo going. Higher oil pressure wouldn't affect leaking at the valve cover gasket.
audiguy00
Mar 20, 2006 10:31 PM
gruey
Dec 30, 2005 11:58 AM
robusto
Aug 8, 2005 05:20 AM
lowrider786
Dec 25, 2004 04:21 PM
