1996 audi a4 fuel delivery issue
Old Jun 21, 2014 | 01:14 AM
E36's Avatar
E36
Default 1996 audi a4 fuel delivery issue
1996 Audi A4 2.8 12v is having fuel delivery issues.
Fuel pump fuse is good
Fuel pump relay is good
Fuel pump is pumping
9 volts to the connectors while cranking
Earlier I got the car to start by jumping the fuel pump with external power, now I can't.
No schrader valve? Any tips, hints or tricks on checking the fuel pressure?
What else too look for?
Old Jun 21, 2014 | 08:57 AM
mtroxel's Avatar
Fuel filter ever been changed?
Old Jun 21, 2014 | 09:11 AM
E36's Avatar
E36
Replaced the fuel filter 2 years ago roughly 15 - 20k miles ago
Went out and bought a fuel pressure gauge and since there was not a valve to test I went directly to the fuel pump put my gauge lines to the feed line and into the feed line to the injector rails after trying to start the engine with the key I got 0 pressure after I manually jumped the fuel pump it was reading 60 - 62 so cranked it over but still wouldn't fire up the car died on me on the free way while I was going 80 had to pull over and never fired up got it home and the fuse was blown changed the fuse and the fuel pump would make the whirling sound as if it was pressuring up but still nothing.
Old Jun 21, 2014 | 09:13 AM
mtroxel's Avatar
Really got to suspect that pump after that blown fuse and your other symptoms. See what someone else says.
Old Jun 23, 2014 | 05:38 PM
E36's Avatar
E36
Turns out it was fuse 34 (Engine Timing). Problem solved.
romanI
Jan 12, 2011 09:32 AM
johnwould
Oct 17, 2009 08:09 PM
Kliminati
Apr 10, 2008 12:23 AM
rketekt
Jan 20, 2007 01:12 AM
ndevore007
Sep 10, 2006 11:51 PM
