2.8 V6 30v fan pulley bearing - stupid crazy expensive
Old Mar 4, 2013 | 11:50 PM
CheckerBird's Avatar
The fan/idler pulley is a crucial component in the serpentine accessory belt circuit on the 30v V6 engine so it can't really be eliminated very easily, especially if you've got an air conditioner compressor driven off the belt.
Old Mar 5, 2013 | 07:37 AM
Mad Cow's Avatar
Not true at all, I ran my AHA like that for a while. That pulley does nothing important other than run the fan, if you eliminate it and run a shorter belt it'll actually cover more of the crank and AC pulleys than stock. I was even able to run a stock belt for a while, but it squealed on startup for a second.
Old Mar 5, 2013 | 10:22 AM
bshusted's Avatar
I did read at one point of some kit to eliminate this pulley all together and use an electric fan. I'm not sure of the cost or any real benefit, but if it's cheaper, you may want to look into it.
Old Mar 5, 2013 | 01:23 PM
Mad Cow's Avatar
All you need to do is cover the gaping hole in the timing covers left by the pulley bracket. If you take the lock carrier off you'll easily be able to fab something up with sheet metal. I was lazy and only covered the front portion because I didn't want to drain the radiator.
Old Nov 22, 2013 | 09:07 AM
TamIAM's Avatar
Originally Posted by Mad Cow
Sorry about that, guess I wasn't paying attention. I do have a solution for that too, though it involves an electric fan and some creativity. On the plus side you'll be getting rid of that stupid clutch fan in the process.
What was the solution for replacing the clutch fan pulley?
Old Nov 22, 2013 | 09:33 AM
Mad Cow's Avatar
Look up a little bit, you take out the bracket completely, make a blockoff plate to cover the hole in the timing covers, buy a serpentine belt one size smaller and run an electric fan.
Old Nov 22, 2013 | 10:02 AM
mtroxel's Avatar
Honestly guys, if you're just trying to save money on a fan clutch, you can find lots of them out there for $45-100. It's not a huge job, and unless you have an electric fan sitting around that fits for free, I'm not sure why you'd do this.
Old Nov 22, 2013 | 12:40 PM
  #18
Mad Cow's Avatar
I can't speak for everyone but I did it because the whole setup was cheaper than an OEM fan clutch, and it frees up a ton of space around the front of the engine so I don't have to contort my arms to reach things.
clubstacker
Oct 22, 2012 02:48 PM
AlyAudi03
Oct 13, 2012 11:11 PM
vousdew
Jul 25, 2008 04:25 PM
cdmx
May 25, 2007 11:31 PM
