2.8 V6 engine removal on 1997 A4 Quattro
Old Apr 28, 2012 | 10:58 AM
fallon's Avatar
see next box.
Old Apr 28, 2012 | 11:00 AM
fallon's Avatar
Originally Posted by jonbonesjones
speed tuning group buy - $130
it does more than add hp
changes throttle response and the torque and power curves
you will notice it and it will feel better
Is that kit for the 30V or 12V? I wasn't sure from your response.
Old Apr 28, 2012 | 11:30 AM
shipo's Avatar
Originally Posted by fallon
Thanks for the replies. I read about "reverse bleeding" and thought I might give that a try to see if it changes anything in the pedal feel. As I mentioned in my previous post, are these clutch pedals normally this soft? I don't want to keep working towards a firmer pedal if one doesn't exist. What I do know is with the car in first gear and the pedal fully depressed, when you turn the key the car moves as if locked in gear. If the clutch was worn out wouldn't the opposite happen? I would think you'd be able to hear/feel the clutch slipping. Again, this hydraulic clutch system is still foriegn to me. The learning curve is pretty steep right now. If only there were some "backyard" checks that could confirm clutch worn vs slave cylinder malfunction. I wouldn't prescribe putting the car in gear and using the starter to move it too often as it puts a terrific load on the starter. But you get the idea. Thanks.
As a general rule I'd say the "feel" of every car I've ever driven with a hydraulically actuated clutch could be described as "soft".
Old Apr 28, 2012 | 02:36 PM
ImTheDevil's Avatar
30v and 1.8T - there are no 12v ECU upgrades.
Old Apr 28, 2012 | 05:26 PM
DOC_DEPALMA's Avatar
Start by bleeding your slave. If he didn't bleed it after the install then there's your problem. Also it's the most simple solution, cheapest and fastest. "All you need is a buddy with a working foot." - The Devil
Old Apr 29, 2012 | 09:49 AM
jonbonesjones's Avatar
Moderator
any tips for bleeding a slave?
i did it on mine last week that thing was so hard to get to i had to snake my arms up there and get covered in fluid
Old Apr 29, 2012 | 11:43 PM
Haha I endured a similar torture. ****** brake fluid in the eyes HURTS!
My advice is wear eye protection and some gloves.
chefro
Jun 26, 2011 12:33 AM
fabmaster911
Jun 19, 2011 02:27 PM
fabmaster911
Jun 15, 2011 11:36 AM
mprezive
Jul 18, 2005 08:22 PM
