2.8V6 12V: engine noise
Old Jun 20, 2011 | 08:00 PM
  #21
vtraudt's Avatar
I still have some valve noise, but 'think' it got better.
Getting the timing perfect (during the timing belt change) seemed to help (compression much more uniform).
Currently on a "2x desludge" diet (1 quart of Pentosil (spell), change oil early after 2000 mls or so; repeat). Also, added some 'old engine, quiet engine' additive which reduced the the valve noise.
Hesitation, poor starting, misfires:
- I mechanically cleaned the TB hole to the EGR (was fully plugged up, solid).
- last week (also on a 1996 12V), looked into engine that was reported ("blown head gasket") to overheat, misfire. Car was definately running not on 6 cyl. Changed plugs (were a bit white for my taste), swapped ICM. No change. VAGcom did NOT show faults, but measuring values for knock where high.
- Later found crack in ignition coil pack. Ordered new and installed: perfect. No valve clutter, no codes (better than mine; this one has at least 240k miles on it, sound like a sewing machine).
==> If EGR codes present, check TB connection/hole to EGR, clean EGR.
==> IF no EGR codes, check intake air and vac lines for leaks (spray carb cleaner or starter fluid in the areas and observe if engine 'hicks up'.
==> Fuel pressure ok?
==> If not fuel or air: ignition (plugs, wires, coils).
Valve train? Can't comment if that would cause your symptoms.
Old Sep 29, 2013 | 09:40 PM
  #22
SamVodden's Avatar
Default have the same problem for a while now. mechanic diagnosed rattle as.damaged cat.
didn't charge me for diagnosis. didnt even quote a repair price... another mechanic confirmed.. didnt want to quote price uless I allowed further diagnosis.
Old Sep 29, 2013 | 10:17 PM
  #23
vtraudt's Avatar
Default rattle can cat
I had 'rattle can' exhaust. Cut the cats out (welded in straight pipes). Unfortunately, (different now) rattle remains, since apparently some broken cat pieces have traveled and now caught in the mufflers. Had hoped they would break down quickly, but has now lasted for 2 months, still rattling at certain RPM/load.
Old Jul 13, 2014 | 06:20 PM
  #24
kevin27h's Avatar
I been having the same problem.. I been looking in my owners manual and I find out that the type of gas you put in has a big affect.. If you ran your car on regular grade that is below 87-90aki it could ccause severe engine damage.Aki stands for anti knock index
Old Apr 7, 2015 | 11:38 AM
  #25
haraldpost's Avatar
Any news?
jraffoul
Apr 10, 2017 06:10 AM
kenman
Sep 12, 2012 02:34 PM
tj19855
Dec 31, 2007 03:28 AM
tbrown
Sep 11, 2006 02:47 PM
