2000 A4 HID problem
okay my car is a 2000 a4 1.8turbo. The came with stock h.i.d and the driver side went. it wasnt the bulbs (g2s i think thats the size) did the ballet went bad? how can i fix this problem? fuse? ballets? what?
Hi, a little more info please? How do you know it isn't the bulb - did you swap them to make sure? Can you swap the ballasts? They are screwed underneath the headlight, you might just have to swap headlights from side to side instead of un-screwing the ballasts. As far the fuse goes, you will have to check that yourself, there should be a fuse listing on the fuse door on the left side of your dash.
yeah i have like 3 set of h.i.d bulbs and try every single one and the driver side still didn't work. ballet?? i think its inside the headlight....
i heard a hummmmin sound from the driver side then it's stop but still no driver headlight
OK, then it's your ballast. If it was a fuse, then the other side would not work. If you tried other HID bulbs that you KNOW work and it still does not power on, there is nothing left to blame but the ballast. It is NOT located inside your headlight, it is located UNDERNEATH the headlight and is held by 6 screws if your car came with OEM HID's. You can get a replacement OEM ballast or buy an aftermarket kit at DDM-Tuning and install it.
