2000 Audi A4 will not start
Old May 12, 2016 | 12:42 PM
snatchman's Avatar
Default 2000 Audi A4 will not start
I have a Audi A4 2000 that will not start. I have narrowed it down to the clutch, either a safety switch or an relay. I have jumpered the safety switch that is attached to the clutch pedal and I am still getting the message press clutch in to start. So is there an relay I can check? Plus I have read in another thread that the convenience module in the trunk can cause this problem. How do I locate this module in the trunk? I also ran a scan, please let me know if you see something in the codes.
Thursday,12,May,2016,12:05:44:04768
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
Ross-Tech: Home
Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2001)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 058-906-018-ATW.lbl
Part No: 4B0 906 018 P
Component: 1.8L R4/5VT G 0006
Coding: 07001
Shop #: WSC 06335
VCID: 2E53E54DEA05E54EDC-5140
5 Faults Found:
16795 - Secondary Air Injection System
P0411 - 35-00 - Incorrect Flow Detected
16825 - EVAP Emission Control Sys
P0441 - 35-10 - Incorrect Flow - Intermittent
18014 - Rough Road/Engine Torque Signal from ABS
P1606 - 35-00 - Electrical Malfunction
16725 - Camshaft Position Sensor (G40)
P0341 - 35-00 - Implausible Signal
17925 - Power Supply Relay for ECU
P1517 - 35-10 - Electrical Malfunction - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 B
Component: ABS/EDS 5.3 FRONT D00
Shop #: BB 24332
VCID: 1D31328197A36ED675-5122
No fault code found.
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 K
Component: Airbag Front+Seite 1002
Coding: 00104
Shop #: WSC 06335
VCID: 3E73D50D3A6515CE4C-517C
9 Faults Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance Too High - Intermittent
00588 - Airbag Igniter; Driver Side (N95)
33-10 - Resistance Too Low - Intermittent
00589 - Airbag Igniter 1; Passenger Side (N131)
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
01218 - Side Airbag Igniter; Passenger Side (N200)
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 980 C
Component: B5-KOMBIINSTR. VDO D11
Coding: 02244
Shop #: WSC 00000
VCID: 2B55EC59D9179066FB-5140
1 Fault Found:
00667 - Ambient Temperature Signal
30-00 - Open or Short to Plus
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump D11
Coding: 16140
Shop #: WSC 06335
VCID: 408FABF54091633E3E-4EB2
6 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06335
VCID: 60CF4B75E051033E1E-4B32
2 Faults Found:
01380 - Alarm triggered by Anti-Theft Sensor; Rear Left
35-00 - -
01382 - Alarm triggered by Anti-Theft Sensor; Front Left
35-00 - -
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00011
Shop #: WSC 06335
VCID: 65C15A61FF736616ED-51B6
End-------------------------(Elapsed Time: 04:09)--------------------------
Old May 13, 2016 | 10:48 AM
A4TurboGuy's Avatar
You're getting a **** load of codes. That's going to make it nearly impossible to say "it's that one thing right there".
You're going to have to take care of each code before you assume your problem isn't caused by a code that already exists, which may look as if it's not even related.
That's my 2 cents.
G/L
Old May 13, 2016 | 12:19 PM
elduderino200's Avatar
Yeah that's a crap ton of codes.
Clear them all first (you have a record here of what as there) and see what comes back immediately, those are likely your biggest problems. Stuff that comes back after a while may be less of an emergency.
Anyway, your camshaft position sensor will allow the car to turn over but not start.
Old May 14, 2016 | 09:34 AM
A4TurboGuy's Avatar
Originally Posted by elduderino200
clear them all first (you have a record here of what as there) and see what comes back immediately, those are likely your biggest problems. Stuff that comes back after a while may be less of an emergency.
+1
Old May 18, 2016 | 07:16 AM
ImTheDevil's Avatar
OP, do you have a 1.8T or a 2.8? You need the crank sensor and one cam sensor functional to start. On a 1.8T that means if your cam sensor is shot you're SOL. If you have a 2.8, it'll run with one bad cam sensor as it can infer the other bank's position based on the readings from one working sensor. In both cars, the crank sensor must be functional.
Old May 18, 2016 | 07:18 AM
ImTheDevil's Avatar
In your engine codes, the rough road ABS code and the SAP code don't matter for this issue. The cam sensor code and ECU intermittent code are the ones to address. Start with the cam sensor replacement - they're cheap and easy - and try again. As stated, clear your codes and see what comes back, so you can separate old codes that no longer are relevant from the ones your car currently is dealing with.
Halfpint2209
Apr 22, 2019 08:42 AM
Audigrls5
Nov 18, 2015 01:57 PM
dallanar
Jun 30, 2010 04:53 AM
zyllek
Jun 25, 2005 11:45 PM
